Question about Mitsubishi WD73727 73" HDTV
WD-73727 Error Code 34 (Abnormal Lamp)
I just purchased a used Mit WD-73727 DLP TV. After setting it up and watching it for about an hour or so, the set turned itself off and the lamp LED came on red. Going thru the diagnostics, I got an error code 34. At this point I think the bulb just burned-out on me, but I resent the system and went to bed. The next morning, I try to turn the TV on. It starts up fine, no problems. Of course, I only had it on for 8-10 min 'cause I had to head to work.
Do you think it's the lamp? I was under the impression (maybe wrongly so) that once it was gone, it was gone.
I got a really good deal on the set and if I need to drop $200 on a lamp I'm still ahead. But if it's something major, I'd like to return the ASAP.
Thanks in Advance!
SOURCE: Mitsubishi WD-52327 52 in. Rear Projection DLP
I have a 2 year old Mitsubishi Rear Projection 52" model WD-52525. I recently experienced the same problem as you. My TV quit without any warning and the red lamp light came on. I bought a replacement lamp just like you did, did everything you did too, but it still didn't work either. Since it's past the 1 yr warranty (of course), I took it in to an authorized service center for an estimate. They determined the light engine failed and it will cost me $816.35 to repair. I already shelled out $240+ for a lamp, $48 for the repair estimate and I said "hell" no, I'm not going to fix it for another $800+ and bought a new TV. I'm writing a letter to Mitsubishi expressing my deep dissatisfaction (to put it mildly) with this faulty product and will be requesting reimbursement, which I probably won't get. I sincerely hope this is not the same problem your TV has, but if it is be prepared for a costly fix.
Posted on Sep 14, 2007
  • 1030 Answers
SOURCE: TV suddenly shuts off and lamp light comes on, but lamp is OK
did you reset the lamp timer? just a guess
Posted on Feb 08, 2008
milmar
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
experttv
  • 203 Answers
SOURCE: I just bought a used
There are a few things that could cause this. The lamp is the most common but I have seen some other werid thing cause this problem (ballast and engine) changing the lamp would be a good way to "shotgun" the repair but if you want to know for certain you will need to call someone out that can troubleshoot it the right way. Good luck and if you need any more information please let me know.
Thank You
Tim
Posted on Sep 11, 2008
gopakumarg43
  • 75320 Answers
SOURCE: I have a mitsubishi 73' tv..we ordered a bulb but that wasn't the problem..,we have power and sound..the code light blinks really 6 times and yellow 1..can't find a code to match that,
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jan 15, 2017
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
TV turned off by itself one day. I pressed reset, timer light blinked green for a minute, then I pressed power and it sounded like it wanted to boot up, but nothing happened and the status light turn
Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
Dec 06, 2012 | Mitsubishi WD-Y65 65" HDTV
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
I just bought a used Mitsubishi WD-73727 DLP TV. After watching it for about an hour or so the set turned itself off and the Lamp LED came on red. Going through the diagnostics, I got a code 34 (Abnormal...
Thank You
Tim
Sep 10, 2008 | Televison & Video
Red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
May 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD73727 73" HDTV Logo
229 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
