Model #65swx20b the magic focus can
  • butler_rober Sep 10, 2008
    where is the convergence located?
  • 4,234 Answers
  • ABRsvcs Sep 10, 2008
    Open up the back and you should see a large silver colored heat sink. The convergence ICs should be attached to that.
    Dan
Set 51uwx20b, how do i fix magic flash to reset factory settings
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
Nov 22, 2011 | Hitachi 51UWX20B 51" Rear Projection...
65SWX20B 65 in. Rear Projection Television: how do i clean my Hitachi 65SWX20B 65 in. Rear Pro...
Remove the upper back cover of the television and clean the back of the screen, the mirror which reflects the image onto the screen, the focusing lenses (do not loosen or remove the wingnuts).
May 05, 2010 | Hitachi 65SWX20B 65" Rear Projection...
Magic focus runs half way & stops &showes a #4 ? one side of a face has a green outline the other side red
You may have a burned out convergence chip. But first, if you haven't already, you can try service mode to adjust convergence. Press the Magic Focusbutton, and then press it again to stop it, and then press the Statusbutton on your remote. Here's a link to the manual convergence procedure (scroll down). Warning-- When I did this the set got stuck in one of the adjustment screens. I had to remove the bottom front panel of the TV to reach the "little blue" reset button to get back a TV picture. But I think this is worth trying before replacing parts.
Mar 02, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Magic Focus does not fix the blue 57UWX20B Hitachi
you need to replace the convergence ICs they are STK392-110 you can get replacements at the following link and they send instalation instructions with pictures so you can do the repair yourself. You need to replace both IC they are both STK392-110 they are located on the large heat sink on the far right side of your Tvs' chassis Heres the link for replacement ICs
http://servicemanuals.vstore.ca/
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Magic focus
you need to replace the convergence Ics thats why youre unable to align the blue. If youd like me to post a link where you can get replacement ICs as well as free tech support and instructions let me know and I will post the link.
Apr 08, 2008 | Hitachi 51F500 51" Rear Projection...
My hitachi 65swx20b
Hi, convergence circuit has failed, unless you have electronic knowledge and soldering equipment you`ll need a tech for that one, questions? email me back, BMW Rider
Feb 26, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi Ultravision Digital TV Model 57SWX20B
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 08, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 65SWX20B 65 in. Rear... Problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 15, 2008 | Hitachi 65SWX20B 65" Rear Projection...
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
