Welcome to Fixya. This is not a driver problem of usb because the Logiix is working fine. Are you using an external card reader or the built in card reader of your computer when connecting the Nexxtech adapter? Can you also provide the make and model of the computer. Please provide the information needed to be able to fix the issue.
Thanks
Thanks for the info. since the card reader is working fine there's no need to any driver and the reader was able to read various cards. Logically speaking In this case most likely that the Adapter is not working properly or it is bad. It does not mean that if the device is a brand new one it can't be defective. If you can return the card adapter to the store you purchase it and ask for a replacement since you were not able to use it.
There are no drivers needed for the micro sd adapter. If your card reader is working fine with other cards then the only thing that is new is the adapter it would only means that it is bad. Why don't you bring it to the store where you purchase it and ask them to test it and see what i mean. There are no other work around for this product. This is just a plug and play device.
I was providing you the possible cause and solution for the issue that you have. Thanks
as I already said....I am using the Logiix lgx-79041 card reader which has an opening for various sd cards etc. and as I already stated it works fine with the other sd card from my camera...windows opens it fine....but no response from the new micro sd card adapter
by the way I am running a windows xp home edition version 2002 sp3, I cannot believe that both units I bought are defective....that does not make any sense to me....they would not stay in business selling these adapters if they come off the assembly line defective.....if you cannot come up with any other ideas ...I suggest that you don't know how to help me and I will not pay for bad advise here!...sorry but that is the way I see it from this end
well...if that is your final answer....it isn't worth $15.00.....
