Question about Toshiba Satellite Pro A10 Notebook
Removing the DVD-ROM drive
I want to replace the original DVD-ROM drive. Can anyone tell me how to remove it from my notebook?
    Champion:
  • 277 Answers
Hi the removel of the dvd drive is easy as taking out the battry 1. Remove the battery from the bottom of the laptop 2. Make sure the laptop is NOT plugged in. 3. There is a release button for the CD/DVD ROM drive on the bottom of the laptop, simply press and hold the release switch and pull the CD/DVD drive out. replace it with your new 1 good luck
Posted on Apr 09, 2006
SOURCE:
How do i remove the cd/dvd drive for my acer3003lc so that a can replace it
You can use the Toshiba Satellite 5205 guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
for the acer 3000
1. At the back of the laptop remove the three screws on the support posts for the screen
2. Open the laptop fully and lift the plastic panel that has the power button.
3. Remove the 2 screws holding the keyboard in place
4. Carefully slide the keyboard towards the monitor and lift.
5. To the left of the keyboard ribbon cable is the screw that's been causing all this grief.
6. Remove, slide out optical drive, reassemble.
Jan 03, 2010 | Acer Aspire 3003LCi Notebook
Tip
Upgrade CD/DVD ROM to CD-RW/DVD ROM
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
on Apr 13, 2008 | Toshiba Satellite 1805-S253 Notebook
HOW DO I CHANGE CD/DVD DRIVE IN A TOSHIBA SATELLITE P105-S6114?
You can use the Toshiba Satellite guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
Sep 21, 2009 | Toshiba Satellite Pro A10 Notebook
DVD Rom replaced
When you switch the original dvd rom to a replacement. you MUST remove the logic board from the original drive and put it into the replacement drive for it to function
Apr 19, 2009 | Microsoft Xbox 360 Pro System Console
Dvd rom does not operate
you need to go to hp.com website, they will able to tell you where you can get a replacement.
it is easier to order it from hp.com
try to clean the lens with a DVD claner first, and try to clean the inside of the DVD drive.by using some compress air.
Oct 24, 2008 | Compaq Presario X1000 Notebook
Removing DVD ROM from LAPTOP Toshiba Satellite A50
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-5205/remove-laptop-dvd-cd-drive.htm
kindly follow this site.
Jun 26, 2008 | Fujitsu AMILO M-6500 Notebook
Removing/replacing dvd rom drive
Hi Jerry
I have written down steps on how to remove the DVD-Rom drive for you.
Toshiba notebooks most screws are marked.
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized. I keep them in small cups separated easier to find and don’t get lost.
1. Remove the laptop battery
2. Carefully lift off the securing strip at the top of the keyboard.
3. Remove the keyboard securing strip.
4. Remove all screws securing the laptop keyboard.
5. Disconnect the keyboard cable from the system board. Lift the edges of the connector first and then carefully disconnect the keyboard cable.
6. Remove screws securing the power switch board.
7. Disconnect the USB cable from the system board \motherboard
8. Lift off the power switch board.
9. Remove all screw from the support plate.
10. Remove the DVD drive securing screw.
11. Slide the DVD drive to the right and remove it.
12. Slide in the new DVD drive and follow this backwards.
Hope this helps it is not hard just have to take time an becareful when removing the securing strip at the top of the keyboard to get to screws.
Any questions I will be glad to help answer for you.
Bill
Jun 24, 2008 | Computers & Internet
Replacing CD?DVD Rom CD-RW Drive for T-30
I would remove the Drive in the meantime to prevent it from slowing down your system untill you can get a new one. You can try new ( more expensive) or ebay. But make sure the person you get it from has a good rating.
Also, sometimes a improperly burned CD will casue your systme to act iratic when its in the drive. Even after removing it.
If this is the case. Try ejecting the drive from windows by going to my computer> select the drive> right click> select " EJECT" and then close it afterwords.
Also you might try removing the device like you would a USB cable. Laptops often consider the CD drive as an attahced device like a USB Drive, Remove it with windows " safely remove Device" at the bottom left, then power off and physically remove it.
Have you also tryed getting all the updates for the laptop? Once you do all this, Re-install it and see if that doesnt help.
Otherwise, just order a new one or get a new laptop, descent ones are not too expensive and with todays technology, anything baught yesterday will be obsolete quickly, no sense in spending lots of time and money trying to fix something that wont be worth it.
Its all up to you on that. Good luck.
Feb 14, 2008 | IBM ThinkPad T30 2366 Notebook
Compaq armada 1750 laptop replacing cd drive
Here's a photographic step by step instruction set on how to get to the CDROM drive. There are also some text with each picture that should give you enough info to get it replaced. Good luck! http://wireball.com/images/armada_gallery/index.html
Sep 18, 2007 | Computers & Internet
DVD-ROM/CD-RW
Either the drive is maulfunctionig or you have a problem with the drivers/ settings. If it's the drive then I'm not sure it will be worth fixing. Try reinstalling the device by removing it from the device manager and reinstalling with the original drivers. good Luck.
May 24, 2006 | Toshiba Satellite 1410-S173 Notebook
Toshiba Satellite Pro A10 Notebook Logo
790 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
