Question about Canon DR-3080CII Path-Through Flatbed Scanner
Canon DR-3080 CII Scanner
Getting a Scanner Error: scanner is busy, operation can not be completed (-4437) when scanning patient charts. Do you know what this means?
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Posted on Aug 25, 2009
    Problem Solver:
  • 3 Answers
Have a Canon CD-3080 scanner that is leaving nicks on the top of the scanned pages... not always in the same place...
any suggestions...
Posted on Oct 19, 2009
  • 32 Answers
The (-4437) is not a familiar Canon error to me. It's probably generated by your scanning software as a generic message for a scanner not ready condition. If the light on the top of the scanner is blinking, the scanner needs service. If not, check the cable to the computer for solid connection or bends/breaks. You can also try running the Capture Perfect program that was bundled with the scanner to see if the problem still occurs and gives you a more specific error message.
Posted on Apr 07, 2009
I am using a software package called Readsoft Forms. I create form definitions for different surveys using this software. when I change to a different form definition to scan I sometimes get an error...
Please try USB connectivity instead of SCSI. It is lot easier and unlike SCSI, there is no sequencing required. (With SCSI, you need to start the device before you start the Computer). You can switch on the scanner when you want!
S. Mohan, Chennai, india.
Jul 26, 2011 | Canon DR-9080C Path-Through Scanner
Hello, I am getting the following error message Scanner is busy, operation can not be completed. Canon DR-6080/7580/9080C Driver Version 1.3.10502.17001 (-4437) I need some assistance. Thank...
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Feb 22, 2011 | Canon DR-3080CII Path-Through Flatbed...
My canon dr-3080 cii is running at a low speed. it was at its maximum and suddenly slowed down. rebooted cpu and switched scanner on /off and chcked settings with no results. please help
Scanner will continue to scan at the same Speed! The problem is in the computer. Check if you have enough disk space, do a 'defrag' on your harddisk, create extra space by deleting unwanted files. IF your processor is slow and if you are scanning in color or converting to PDF while scanning, it may slow down the output.
S. Mohan, Chennai, India
Dec 22, 2010 | Canon DR-3080CII Path-Through Flatbed...
I have a canon 6080 scanner. getting a error "no
Clean the two 'black dots' in the paper tray, just under the roller. They are actually paper sensors. Try 'page counting'. If this works, the scanner is okay. If the problem still persists, try reloading the scanning software.
Nov 17, 2010 | Canon DR-6080 Path-Through Scanner
My scanner won't scan. I get the message " Scanner is busy, operation can not be completed. Canon DR-2010C Driver Version 1.1.10805.18001 (-4437).
This may mean that something is using it or that something is interfering with it. Try turning everything off, your computer AND your scanner. Wait a minute or two and then turn your scanner on first and the turn your computer back on. When your computer boots back up don't open anything except the scanner. If your still getting the message then there is something else (another attached peripheral) that may be interfering with the scanner.
Oct 29, 2010 | Canon DR-2010C Flatbed Scanner
Canon DR-3080 CII scans only half or right side of document
Try all formats, Color, Grey & Black & white. If you have problem it could be the scan module. Check for loose contacts, but this is rare in a working machine.
S. Mohan
Oct 02, 2009 | Canon Office Equipment & Supplies
Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
E15 error codes on a canon dr7580c scanner
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
Oct 12, 2007 | Canon DR-9080C Path-Through Scanner
Canon DR-3080CII Path-Through Flatbed Scanner Logo
3,549 people viewed this question
old marine
old marine
