Question about GE Microwave Ovens
The over the stove microwave that was purchased was installed by my carpenter and it would not work when he got it installed then had to comme back and take it down not I will have to pay again to install. My question is how do I go about geting reimbursed?
  • GE Master
  • 9,086 Answers
Manufacturer warranties never cover any incidental costs such as transporting the unit for service or installation.
I would suggest taking the microwave back to the dealer for an exchange if you haven't already.
(After 30 days in most cases, it cannot be returned but instead must be repaired by a GE-authorized servicer. You can find a GE-authorized servicer by calling GE Appliance Service at 1-800-848-7620)
I would insist that the installer test the new one before transporting or installing it.
Posted on Sep 16, 2008
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
Replace vent over stove with microwave & the
So are you saying that the vent hole doesn't line up with the microwave vent hole? I had a similar problem, it didn't matter since most of the new over the stove microwaves can vent back into the house as an option.
Sep 14, 2009 | Microwave Ovens
We have had custom cabinets made for our kitchen and have installed a microwave above the stove and it is to high for my wife, She is 5'4" tall and can hardly see in the micro wave. The carpenter doesn't...
you will also need to consider space between the stove & microwave, but you could go back to your cabinet company and have them make you a dead panel that matches your cabinets for the face side of the microwave. then you will also need three other pieces 1 for each side and 1 for the back! if you want to drop the microwave down 12 inches have your panels cut 12 inches! have your carpenter block in and attach panels, go to a fastner company with 1 of the bolts that the microwave came with to hang it from the cabnit and find or order bolts the compensate for the depth in which you you have your panels built!
May 31, 2009 | Microwave Ovens
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Blower motor on above stove microwave not running
The dual fan in the back is the vent / exhaust / hood fa. It will run when you turn it on, or if the stove top gets too hot.
The other fan is the magnetron cooling fan, and it will only run when you are cooking. If it is not running, your magnetron can be destroyed.
You can download GE owner's manuals and installation instructions here. That may help you a lot.
Please reply back with more details if this is not yet a FixYa...
Aug 17, 2008 | Microwave Ovens
Microwave
It sounds like there may be a blown fuse. The back of the mw oven will have to be removed to check. Some ovens only have a thermal fuse and not a traditional glass fuse. If that is the case you should call a technician to repair it unless you know how to use a soldering iron.
Dec 26, 2007 | Microwave Ovens
Need help figuring out microwave installation above stove
Not sure I understand the question, but is building your own cabinet or enclosure an option?
If not, please feel free to write us back if you can clarify this matter further.
We'd be happy to help.
Nov 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
