Question about Philips Magnavox 20MT133S 20" TV
Top ~1¼" of the picture being overscanned into top ~½"
The top ~1¼" of the picture appears to be overscanned into top ~½" leaving the top 1¼" of the screen empty (black). In effect, it appears that what is supposed to appear in the top 1¼" of the screen is being jammed into the top ½" of the picture.
That makes it really tough when watching an NFL game on Fox with the game details posted in a bar along the top. :-)
There is only one unmarked adjustment port on the reay of this set.
Thank in advance for any help in correcting this issue.
  • 2 more comments
  • M1952 Sep 11, 2008
    I am comfortable with electronics soldiering and the only thing in that realm that I hope I never have to do again is adding/replacing any of those teeny-tiny SMCs ... . I did that on a couple of old mini-laptops and vidcards in order to OC them. I don't foresee any issues (de)soldering capacitors.
    While I have never modded anything inside a TV set, I figure it shouldn't be fundamentally different from the computer mods that I have done over the years ... I will just be careful to avoid the components that may zap me ... like BIG caps. :-)
    I look forward to your instructions. Thanks so much for your help, Dan!
    Kim
  • M1952 Sep 18, 2008
    Dan?
  • M1952 Sep 19, 2008
    Hmmm ... I thought that Dan would return to tell me on which board the vertical circuit lives and how to ID the bad capacitor.
    Now I am told that there are several things that it can be.
    I suppose that the next best step for me is to haul that TV off of the fridge tomorrow morning, open 'er up and look for one or more obviously toasted components ... and take a LOT of digipics for later reference before I put it back together and return it to the fridge.
  • M1952 Sep 21, 2008
    I cracked the case and immediately saw a hotspot on the PCB ... so I took some pics & readings before returning the TV to its home atop the fridge.
    Here are some pics:
    http://i7.photobucket.com/albums/y285/Ju...
    The hotspot seems to be generally centered on 3 axial resistors (PCB#s 3423, 3443, 3444). As a quick volt-ohmmeter check I read the easily accessible big, horizontal axial resistor in the pic (by the Molex) and it reads correctly as 33ohms.
    The two closest edge of the board (3443, 3444) only read ~1.2ohms which cannot be correct. They appear to be IDed as 210ohm (red/brn?/brn?) but their striping is a bit odd and I never was good at reading the stripe colors on the small ones, especially when their surface is not flat & glossy.
    The third one in question (3423) reads ~35ohm but its striping is Blu/Gry?/Blk which indicates that it is a 68ohm resistor. Even if I am off on the second stripe color, the BLUE is obvious, so this should be a Sixty-something ohm resistor.
    It appears that these 3 resistors, at least, need to be replaced. Anyone have a schematic for this TV that would give me the specifics on these 3 resistors?
    I am also soliciting any other thoughts from you experts. This is my first TV repair and I am not going to assume that replacing these three resistors will correct my problem, although it looks like an excellent place to start. ;-)
    Thanks!
    Kim
  • 4,234 Answers
First, my apologoes for the delay. I was called out on site for a major production and my access here has been limited. I do have the service manual for this set and intend to look up the pffending circuit tonight. I have listed the items you provided as target components for checking and will post the relevant parts of the vertical circuit.
Dan
Posted on Sep 22, 2008
  • 4,472 Answers
Https://www.manualsparadise.com/ShowProductsForModel.do?model=M39589528\
You can purchase the service manual from the above link. That will give you all the info you need. If you have a moment please accept and rate this solution accordingly as I strive to provide fast, economical, and accurate solutions.
Thanks and enjoy,
Lee
Posted on Sep 21, 2008
  • 2,071 Answers
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Posted on Sep 19, 2008
    Master:
  • 497 Answers
A missing power supply voltage, defective vertical output IC, or a component associated with it is likely bad. A bad connection or blown fusable resistor may be the cause of a missing power supply voltage
Thanks for using Fixya!
tc
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
MacBook Pro Want to stretch image 'full screen;' however, when I use stretch resolution, I can't see the top menu bar.
This is a fairly common problem when connecting the MacBook Pro to most Televisions.
Step 1.) Click on the Apple logo and select "System Preferences".
Step 2.) Click on the Display icon (it should be somewhere similar to the one pictured below).
Step 3.) You should get a screen that looks like this, make sure the box that says "overscan" is not checked. If it is checked, click on it to uncheck it. This should make the top menu bar visible, but it will not stretch the desktop image all the way to the sides. I hope this helps you out.
Feb 01, 2011 | Samsung SyncMaster P2770FH TV
White dashes across top left of TV screen
That is what I was going yo suggest. You can also adjust the picture size. "Just" will show all of the picture even the distortions on the edges. "Full" will in effect overscan and trim those edges off.
Apr 27, 2009 | Panasonic SC-DT100 System
Top picture overscan issue, again ...
Overscanned in the top of the screen,is the symptom defected capacitor in the vertical section. Filter capacitor 100uf or microfarad or it is better you replaced all capacitor there and reworks or resolder all solder joint there in vertical section.So it will works better again..
Regards,.
VOTIT
Sep 18, 2008 | Philips Magnavox 20MT133S 20" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Overscan
do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Jul 23, 2008 | Toshiba 55H70 55" Rear Projection...
Top of picture cut off
Sounds like a problem on the deflection/power board....You can try replacing the vertical I/C and caps.......Or go for a new board.
Jan 01, 2008 | Pioneer PRO-710HD 64" Rear Projection...
OverScanning???
it sounds like a pin-cussion correction circuit failure. A tricky circuit to troubleshoot even for an experienced tech. check servicemanuals.net for info
May 14, 2007 | JVC AV-32F475 32" TV
Philips Magnavox 20MT133S 20" TV Logo
151 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
