Dell2400 will not boot - Computers & Internet
    Problem Solver:
  • 5 Answers
Hmm...
I think we need a bit more information.
Does the power come on? Do you see the Dell screen? Does windows load at all?
more info!
Posted on Sep 10, 2008
What can I do to boot my PC without using the F8 key?
If you have to select the boot device every time, this means that the BIOS (CMOS) setup does not have the boot device listed as the first device to boot from. At startup, press the key that enters CMOS (BIOS), usually DELETE, or possibly F2. Once in the CMOS, look for boot options, then boot devices, then boot sequence. Find your device and ensure that it is listed first in the boot order sequence. Then save the changes and reboot. You may have it set for a USB or network boot first and it won't boot without intervention.
Aug 15, 2016 | Computers & Internet
I want to add printer to my dell2400 and there is a CD stuck in drive
very often there is a small hole in desktop based optical drives. using a straightened paperclip [needle; pin...] exert gentle steady pressure through this opening and the disc should eject.
IF the disc can be seen in Windows Explorer; an eject command may be recognized
Feb 19, 2012 | Dell Dimension 2400 PC Desktop
What adapter if any can be used for dell2400 to connect wireless
Most of the wireless adapters available now are compatible to all the computer system.
You can just buy a wireless adapter to any electronic/computer store and it should work after installing the software/driver that came in with the device.
Note when buying any device for your computer:
Always check for the Operating system compatibility of the device.
e.g. : if you have a windows XP system, make sure that the device is compatible with it.
Do the same if you have windows vista, 7 or any other operating system.
Thanks,
~jash
Aug 10, 2011 | Computers & Internet
D5 error on MB durring POST
i am william too i forgot password dell2400
Oct 22, 2009 | Tyan Computers & Internet
How do I retrieve password for Dell2400 print server?
Try this, just copy and paste this link. It's to Dell support.
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?c=us&cs=19&l=en&s=dhs&~ck=mn&SystemID=PRN_LSR_2335DN
Hope this helps.
JimmyC
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
What to i need to upgrade my dell 2400 to be wireless and wifi
WiFi -- As for the WiFi card that is literally plug and play, particularly if you have the XP service pack w/ the wireless networking utility.
What you want to do is purchace a PCI wifi card. I usually get my parts from tigerdirect.com or newegg.com. Once you get it in, you will need to remove the screws holding on the side of the computer(usually the left pannel) and you will then see 3 small empty slots on the motherboard. you will slide in the wifi card untill the two hooks on the side of the slot click into place. (Make sure you are as grounded as possible before taking out the wifi card from the static free bag.) When you buy the wifi card, it will probally come with a cd with drivers on it. install those before installing the actual card.
Mar 06, 2009 | Dell Dimension 2400 PC Desktop
Snowboard boot type
"Snowboard Boots - Function and Types of Snowboarding Boots Good Snowboard Boots should give you maximum control over your Snowboard, protect your feet and ankles from the pressures of high speed turns, and keep your feet warm and breathing in all weather conditions at the same time. Boots come in many variations and Styles. There are Different Types of Snowboard Boots appropriate for the Three Riding Styles in Snowboarding. Currently, a lot of boarders prefer soft boots with Strap Snowboard Bindings, but step-ins are a convenient alternative. What follows are descriptions of the most common types of Snowboard Boots: Soft Boots Softboot Soft Boots are most comfortable and can be used with highback bindings and flow-in bindings. This type of Snowboard Boots allows for a large amount of movement in just about any direction. Consequently, soft boots are a must for pulling tricks since they are great for doing whatever you want. Soft Boots consist of two parts: an inner bladder and an outer boot. The inner bladder is padded to keep your feet warm, dry and protected from heavy impacts. It usually has its own lacing so you can tighten the inner bladder independently from the outer boot. The outer boot has a sturdy upper part that allows for ankle movement. The outer lacing allows you to further tighten the Boots. In contrast to Hard Boots and Ski Boots, Soft Boots are pretty comfortable for walking and even driving your car when you're not on the board. Soft Boots are currently the Most Popular Type of Snowboard Boots and are preferred by Freestylers and Freeriders. Although there is a wide range of Soft Boot Styles for both Freestyle and Freeride Snowboarding, the main difference in the different styles is in the degree of Boot Flex. Soft Boots with a stiffer upper boot and a higher cuff with a lace-up inner boot for enhanced firmness are Freeride Soft Boot Styles. Conversely, Soft Boots with loose, molded-foam inner boots for more flexibility are Freestyle Soft Boots. Hard Boots Hardboot This Type of Snowboard Boots is designed for precise control. Hard Boots support your foot, ankle, and lower leg firmly, making them best for racing and high-speed carving on hard snow. Hard Boots have a padded inner bladder similar to the ones in Soft Boots. The outer shell however is made out of hard plastic and is usually adjusted (or closed) using buckles or ratchet bails. The benefit of having hard plastic as an outer shell is that it gives riders more precision and power in edging movements. Hard Boots resemble the traditional Ski Boots. However, the Hard Boots have lateral mobility for the ankle. To provide some flexibility, hinges are often built into the ankles. The soles of Hard Boots usually have a mechanism that allows them to be connected to Plate Bindings. Hard Boots are often used with plate bindings by Alpine Racers who want their movement to be directly transferred from the Hard Boots and Snowboard Bindings onto the Snowboard. On the contrary, Hard Boots are not suitable for Freestyle Snowboarding tricks and maneuvers since they limit the amount of flexibility. This Type of Snowboard Boots is pretty specific and seriously lessens your freedom in choice. If you're planning to buy this, make sure you find an exact match between the Binding Mechanism and the Hard Boot Mechanism. Also, make sure you can flex the Hard Boot forward easily and smoothly so as to avoid mishaps during transitions. Hybrid Step-In Boots Hybrid boot These Snowboard Boots are a good choice for those who want the convenience of a strapless system. Hybrid Step-in Boots combine the flexible, soft upper part of Soft Boots and the sturdy hard soles of Hard Boots. They are used in combination with Step-in Bindings. People who are looking for a mix between the comfort and flexibility of Soft Boots and the control of Hard Boots will often opt for Hybrid Step-in Boots. As with Hard Boots, you will need to find a match between the Step-in Binding mechanism and the Boot mechanism. Before you buy Snowboard Boots, you must first decide whether you want to go with a Step-in Binding or a traditional Strap Binding. Remember, while traditional Strap Bindings will work with any non-Step-in Boots, Step-in Boots must be purchased together with their corresponding Bindings. Also, keep in mind that Hard Boot systems work best in harder snow conditions, while soft boot systems work best in softer conditions. "
Dec 01, 2008 | Kicker Forum SLR Snowboard Boots
Dell 2400 dimension desktop
When you said "I think its a memory problem" your right, you need more of it. Try adding more RAM. It's really cheap now a days, especially for the 2400. Memory is available everywhere. While this is not an endorsement of their site, Computer Memory Outlet.com has about the cheapest RAM available and they are reputable and reliable and orders usually ship next day. I personally get all my memory from them.
anaanymous
p.s. They have an on site utility that will scan your computer and tell you the exact RAM you need and the maximum RAM you can add
Oct 12, 2008 | Dell Dimension 2400 PC Desktop
Dell monitor power down mode with Geforce GFX card install
I think maybe some how the main graphics for your pc has possibly switched to onboard. Try getting into bios F2 or DEl on boot up and highlight Advanced ChipsetFeatures and press Enter. In here make sure your AGP card is set as the Primary graphics controller. When done press ESC and 'Y' to save settings, then re-boot pc. Hope this gets you running again.
Nov 10, 2006 | Dell (M1325) (64 MB) Graphic Card
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
