Question about Barbeques Galore Turbo Classic 3-Burner 207795 (LP) Grill
Gas BBQ - Won't light
I have a Vermont Castings BBQ and recently switched the propane tanks. THe grill was working fine and now it does not seem to be getting any gas. I hooked up the new tank and turned it on and it won't fire. There is no smell of propane and the starter is not the issue as I also tried lighting it manually. Is it possible the connection is not being made at the tank? Are there gaskets that I need to check for on the tank and connector to make sure it is set up properly? Any help would be greatly appreciated. Thank you.
  • 1 more comment
  • chump Nov 03, 2007
    I have the same problem with a vermont castings bbq. Model VCP751AP. Tried two tanks, both full and same. Was working fine before I disconnected, now when I hook up either full tank, no gas seems to be flowing. Both manual and auto lighting dont work
  • Anonymous Apr 16, 2008
    Having exactly the same problem with my 1 year new Gas BBQ. Help!
  • berni464 May 06, 2009
    I have also tried 2 tanks, and cannot get a fire...It was working perfectly when it ran out of propane..One fix , was to drop it on the ground from a couple inches acouple times or more, to loosen something. Tried that on the first , then did it for good measure before hooking up the 2nd..still no connection...These have been exchange tanks. I wish I had just gotten MY original tank filled...
    something has to be done, besides buying a new BBQ....
    Champion:
  • 277 Answers
Hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Posted on Apr 09, 2006
I have a uniflame bbq i get my propane from walmart through the refill program i hook up my tank to my bbq and it wont light it almost seems like the bbq isnt getting enough fuel all i get is a low flame HELP
Posted on May 15, 2011
I was having the same problem with the burners not getting very hot, like it was not getting enough gas. I bounced the tank on the ground a couple of times and then turned it sideways and left it that way while I was cooking. Now I have too much flame lol. It has something to do with the tank. Good luck
Posted on Jan 17, 2011
There is a shut off valve in the tank. If you connect the tank too quickly this valve will be triggered. There is a way to disconnect, wait 5 min with the burner valves open, then reconnect and open the tank valve very, very slowly. This is a real pain in th @$$ when you people waiting for food. I have found that if you invert the tank this resets the shut off valve quickly..
Good luck.
Posted on Aug 16, 2008
  • vscarb04 Jun 04, 2011
    THANKS!!! You saved the day!!! Inverted the tank as you recommended
  • 3 Answers
With my weber bbq, you would turn off all the burner valves on the bbq and close the tank valve. Diconnect the hose from the tank and then open all the valves for the burners and leave on high for 1 minute. Shut the burner valves off and reconnect the hose and relight as normal. Works every time
Posted on Jun 27, 2012
Can I convert a NG Vermont Castings BBQ to Propane. moving and new house has no NG available. Model SCS 5005.
Unfortunately, Peter, for safety reasons, VC grills are not approved to be converted from one gas type to another. Each grill is manufactured, tested and approved for it's specific gas type. Converting it from LP to Natural Gas places all the liability on you, if something should go wrong as a result of the conversion. Further, you would notice a significant change in the heating ability and the lower flame height, when set on high. The reason for this, is that LP Gas burns cleaner and hotter than Natural Gas in an outdoor environment.
I know you would be happy not having to refill the tank, but I think you would really disappointed in the performance of the grill, if converted to Natural Gas.
I hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Sep 15, 2011 | Weber Grilling
I have a Vermont Casting VM450SSP Grill that needs a new Hose Regulator-S/B Valve Assembly. I have ordered two separate times what "Appliance Factory Parts" thinks is the part I need and both...
This ma=y be a case of changes in parts for your VC Grill. The ownership of Vermont Castings changed 6 years ago, when Majestic Fireplace, who was then the owner went bankrupt and Monesson Hearth products bought VC in the bankruptcy. Shortly there after, Monesson made some sweeping changes to the grill line (your model was discontinued) and really up graded what Majestic Fireplace had done with that line of grills. Overall, they started building a better quality grill.
Unless you have a piped in high pressure propane gas system, the one that Appliance Factory Parts furnished you should work fine (based on what I saw on their website). In addition, if you purchased your grill, prior to the change in 20lb LP Gas Grill Tanks Valves, 6 years ago. Some manufacturers changed their grill hoses to conform with the new OPD Valve grill tanks. It wasn't required, they just did it, to avoid regulators locking up, when the tank valve is opened to fast.
Hope this helped answer and solve the problem for you. Happy Grilling!!
Jun 18, 2011 | Vermont American Tool Company VM450SSP...
I want to convert my vm 600bsn grill from natural gas to propane
Because you bought your grill at Lowe's/Home Dept there is no conversion kit available. Conversion kits are available only for the MHSC made Vermont Castings grills sold at authorized dealer locations. If you are interested in a genuine Vermont Castings grill please visit www.ibuybarbecues.com or www.ibuyvermontgrills.com
Apr 11, 2011 | Vermont Casting VM600BSN Grill
I have a Vermont Casting 3 burner BBQ, Model VM400XBP, 36,000BTU grill that won't go above 300 degrees? How can I fix it?
It could be something as simple as a triggered safety feature within the gas tank itself. These new tanks will react to the gas leaving the tank at a high flow rate causing low burner temps. To remedy: shut off gas and remove tank. Open and close all valves on the grill. Reattach the tank and SLOWLY open the valve 2 turns. Then retry. See page 13
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 28, 2010 | Vermont American Tool Company VM600BSP...
Vermont castings Medallion CF9080 wiring burst into flames
First of all i would find out what city this company was in, and who owned it, then i would contact the district attourney in that city and see what they can do too get this remidied, this may be what is called a fly by night company, and they may or may not have a parent company....hope this helps....
May 22, 2009 | Grilling
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Barbeques Galore Turbo Classic 3-Burner 207795 (LP) Grill Logo
10,909 people viewed this question
Top Barbeques Galore Grilling Experts
Paul Carew
Oloyede Monsuru
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
