Question about Hotpoint Washing Machines
Hotpoint wt450 when you select any program it will fill and then pump out water the drum does not rotate at all on/off light flashes and different lights depending on program selection it just pumps out till you switch off jim
5 Suggested Answers
  • 619 Answers
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
  • 1003 Answers
SOURCE: washer dryer - dryer does not heat up
REPLACE HEAT ELEMENT TO SOLVE DRYER PROBLEM
Posted on Feb 02, 2008
barkencoa
  • 3463 Answers
SOURCE: I have a Hotpoint WM52 that fills but will not spin / rinse
Check the brushes in the motor, and replace if less than 5mm or or so in length.
Please rate my solution.
Thanks.
Posted on Aug 11, 2009
  • 1531 Answers
SOURCE: Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Posted on Sep 16, 2009
Hotpoint aq7L149i washing machine flashing lights ?
Hi Jason.
The most likely reason for your problem is that the water inlet valve is faulty. This is why the machine won't fill.
It is a simple fix for a serviceman.
Good luck.
Nomess
Nov 21, 2014 | Hotpoint Washing Machines
Hi, I have a Hotpoint Aquarius WF530 washing machine. When I put on a wash program I hear the pump running as per normal part of cycle but nothing else happens. Drum does not fill with water... If I turn...
most probally the control module (bottom of machine) emw electronics are your best bet for a replacement, as otherwise they have to be programmed by hotpoint
Sep 09, 2013 | Hotpoint Aquarius WD640 Front Load...
All the function lights and pause lights flash
follow the steps and fix it. USE the VOM . God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
Fills with water but will not wash
Thank you for using FixYa. Does the program still run it's course and pump the water out? If it does and it is only the drum that doesn't rotate, it is likely that the belt has either come off or has brocken.
The belt can be accessed by removing the panel of the rear of the machine.
Hope this helps
Duncan
Mar 04, 2011 | Hotpoint Washing Machines
When I start any program on my Miele Novotronic W820, the machine fills with water and drum starts to turn but after a short time the main wash light flashes on and off. I've tried clearing the program,...
you may find that the water pump is not operating properly as the first fill of water is normally pumpt out first before the wash fill is started unplug the machine and take the back panel off and locate the water pump and check if you can move the cooling fan at the rear of the pump freely if not the take the water outlet pipe off and remove whatever is stopping the rotation of the pump replace all parts and run the machine to see if the fault has been found and cleared eric
Jan 05, 2018 | Washing Machines
Fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Oct 10, 2009 | Hotpoint WMA46 Front Load Washer
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
100 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
