Question about Canon NP 6551 Black and White Copier
Canon NP 6025 Sorter error
My Machine tells me to disconnest sorter ,when i turn it on .
machine will work when i disconnect sorter ,but i need the sorter can any body help
No error cde
Posted on Sep 16, 2008
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
If you tell us what the problem or error code is ??????????????????????
Posted on Sep 10, 2008
Error c0b31. can someone tell me how to fix this error?
The code to refer the staple sorter unit malfunction.Check the sorter motors and sensorrs,clean it and disconnect and connect the sorter plug on the copier machine for reset the problem.If to work to disconnect mode your problem in the sorter unit.
Jul 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Cannon NP6521, 531e error
check the sorter staple motor sensor or remove the sorter from the machine
Jan 06, 2010 | Canon NP 6050 Copier
Digital replacement for Canon NP 6025
"No" is the answer to all of those questions, and even if it were "yes", purchasing a good quality refurbished digital machine from a reputable supplier, would still be a far cheaper option than all of that.
Not in or around Toronto, are you?
Mar 12, 2009 | Canon NP 6551 Black and White Copier
Canon Np 6551 e502
that error is a communication error between the copier and the sorter unplug the sorter then turn the copier on should go away. probably loose connector or bad sorter board
Dec 19, 2008 | Canon NP 6551 Black and White Copier
A E532 code deals with the sorter. Are the bins moving at all, also try to unjam the stapler. Also have you tried to let the machine warm up with the sorter moved away from the copier? How about this have you tried to turn the copier OFF then disconnect the sorters plug from the back of the copier and turn it back ON with the sorter moved away from the copier. If it works you are all set. I believe your copier is a older model and for the 10 bin sorter that it comes with may not be worth repairing. If it is a 10 bin sorter, it was never a good design from Canon, they work or don't work.. Good Luck...
Sep 28, 2008 | Canon imageRUNNER C3200 Copier
loks to me like you have a problem... serious problem might be time to go buy a new machine. i know of the best place to get a fully functional machine. GUARANTEED (858) 292-4129 KCDS/BMU
Jul 24, 2008 | Canon NP 6050 Copier
Np6545- erroe code e522
Hello Good Day amazingfirst! you problem for Canon NP-6545 error code E522 according to my Service Manual the problem is the Sorter push bar motor. try to check the sorter motor, add grease if needed so. just focus on the sorter motor ok! there is no need to reset the error code just on and off the machine and it will automatic reset the error code but make sure that the sorter motor will works ok!
Jul 15, 2008 | Canon NP 6545 Copier
Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Jun 06, 2008 | Canon NP 6050 Copier
Canon NP6050
The E510 is a sorter feed moter problem moter (M1) You can see if the sorter moter turnes if it does not,replace it
If you want a quick cure to get you copying disconnect the sorter remove the communications lead you have to remove the sorter completely and the copier will work.
Thank You
Mar 11, 2008 | Canon NP 6050 Copier
Canon NP 6551 Black and White Copier Logo
142 people viewed this question
old marine
old marine
