Question about Frigidaire CWS3600AS Top Load Washer
Frigidaire front load washer - e10 and water hose shaking
Water going into washing machine causes metal water hose to shake and bang. Sometimes this causes an "e10" error on the machine. Customer service said washer is filling and draining at the same time and to make sure the drain hose isn't too long. I cut off several inches so it is the suggested 5-7 inches into the drain. Problem not solved. What next?
    President:
  • 1,197 Answers
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Posted on Aug 30, 2010
Error E10 keeps popping up and washer stops 2 or 3 times during cycle and have to reset it
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Here could find additioan sample guide details: fixed-frigidaire-affinity-washer-gives-e10-error
Hope helps.
May 03, 2011 | Frigidaire ATF6000ES Front Load Washer
E 10 code what do u do
I'm assuming your washer is a Kenmore or Frigidaire front loading washer. E10 error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Jan 10, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
I have an frigidaire front load Mod.# GLTF2940ESO with an recurring E10 error message. HELP!!
Apr 11, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a Frigidaire gallery series front load washer that flashes an E10 error code. What is this for.
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
Oct 18, 2009 | Frigidaire Affinity ATF6000F Front Load...
Wash starts, then stops postin E10 and now soap does not dispense
Aug 02, 2009 | Frigidaire GLTF2940F Front Load Washer
My washer is showing a code
    • Opening the faucet and watch for running water if you have water
  3. Can be caused by bad pressure switch
  4. Can also be caused by clogged pump
  5. also by too low of a drain hose height.
    Check for clean filters of the inlet water line.
    Check that the drain hose was assembled as per the manual's instructions.
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Front load washer, Starts to Fill, then Flashes E10, Was wondering what this code is referring to
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
108 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
