Question about Koutech Systems Koutech KW-2103MS Memory Stick USB Card Reader/Writer, Retail (dsktkw2103ms)
Usb Memory stick
My usb memory stick had very important documents on it, however it is not being read by my computer. I have tried to insert it into 3 different computers and I have the same problem. Can it be currupt? How can I retrieve the files?
  • rajithp46 May 11, 2010
    My memmory card not except any video and photos mp3 will except what the problem pls solvve my problem
  • 2,794 Answers
If it isn't working on three different computers, it's probably corrupted.  If you can't see it on you drive listing under computer, then it's going to be tough to retrieve to documents.
Posted on Sep 10, 2008
Re MiBody 360 Personal scale. downloaded software successfully (Windows XP) inserted USB into scale and stepped on . waited for a few seconds then put USB in PC but no data transferred (PC recognised USB...
Make sure that you have selected USR1 each time you weigh yourself.
When you stand on the scales it records your measurements against that user ID and holds them in the internal memory of the scales.
When you have taken a few readings and when you are not standing on the scales, insert your USB memory stick (any memory stick will do) and press the SET button. The scales display "USB" and write the data out to the memory stick and gives you a message "END" afterwards. When you insert the memory stick into your computer you can read the data into the Homedics software
Aug 26, 2013 | Health & Beauty
Sony memory stick duo pro 1gb is using for Sony handycam is suddenly started giving error message like reinsert memory stick. I have important pictures and video in it, now i need to recovery them. Do...
Hi Devika,
Buy a card reader that can read your memory card and connect to the computer. (Less than $8 in Sri Lanka). Connect it to PC and insert the card to the card reader.
Download Recuva and run it. select the memory card. Try to recover the files.
Best of Luck!
Sep 21, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
How do I download my pictures from my Sony camera to the computer?
Here is one instructional video tutorial from Sony Support; also could try this procedure:
- Take off your memory stick from your camera and insert it into your memory stick adapter. Open your camera's battery case and gently push the memory stick until you hear a faint "click," then remove it from the camera. Place the memory stick inside the adapter that comes with your camera.
- Insert the adapter into your computer's memory card reader, if you have one. The adapter, which is larger than the memory stick itself, is approximately the same size as an ordinary SD memory card.
- Connect your Sony digital camera to your computer using its USB cable if you can't find or don't have a memory stick adapter. Insert the small end of the USB cable into the camera. Insert the wider, flatter end into one of your computer's USB ports.
- Click "Open Device to View Files" to open your memory stick or camera. Search for the DCIM folder and click on it. Navigate through any photo subdirectories you've created and highlight photos you want to transfer to your computer. Right-click anywhere in a given folder, then click "Copy." Go to the location where you want to store your images, then right-click within that folder. Click "Paste" to transfer your images.
Hope this helps (remember to rate and comment this answer).
Jul 03, 2011 | Cameras
Plz help me ......... i dono rmmbr my memory card password.... and it contains very much important data........ and my set is nokia 7230 which does not support .sis file.
>purchase a memory card reader
> insert the memory card in it
> connect memory card reader with computer USB port
> copy all important documents to your computer
Jan 31, 2011 | Kingston 4GB Secure Digital High Capacity...
Hi, I can view the pictures of a memory stick on my camera, but when I put it in the sleeve and insert it in the computer, the computer can not read the disk. I have also used the USB wires hooking the...
possibility: the memory card is not formatted in a way that your computer to recognize it.
give this a try...
*format the memory card first (FAT32 or NTFS) using your computer
*put the memory card back to your cam, then click away
*then try to read it again in the pc.
Jun 22, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I have purchased a memory stick[8GB] and I need to know how to use it
Hello !
If you are familiar with floppy disks (were placed in the "A" drive) from years ago, the memory stick works in the same way. Instead of saving to the "A" drive, you would save to a drive letter.
If you have a computer that is less than 8 years old, you probably have a USB port. The USB port is rectangular in shape.
Place the memory stick in your USB port (any USB port). The stick only goes one way. So if it does not fit, flip it over and try again. Do not force it.
You should see a message displaying a drive letter (probably "E", "F" or "G") that has been created. Note that drive letter.
Now, the memory stick will allow you to save your files to the "E", "F" or "G" drive. Your computer's hard drive is "C". When you save files (in a document, for example), you are saving to your "C" drive. To save to the memory stick, select "Save As" with in your software program, such as Word, and select the memory stick's drive letter. Your document will be saved to your memory stick. Note that the light will go on the memory stick as it saves your document.
When you are finished with the memory stick, look for a symbol on your Toolbar (near the date/time). Right-click the item and select "Eject" and you'll get a message that it is safe to remove your hardware.
Please note to never remove your memory stick when your are saving a document or other file.
That's it !!
Hope this helps.
Oct 09, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sony Memory Stick PRO Duo Not reading
Get a USB card reader, insert the memory card into the card reader and then connect the card reader into the USB port of your computer.
The computer will see the memory as an external memory device, now you can view the data/images and copy them to your computer.
Feb 13, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
USB Memory stick
Yep, if it does not open on any computer the disk format is gone. There are companies that do data recovery like this one:
Data Recovery for USB flash drives and portable data storage devices
They are expensive, and they do not guarantee success, but if the files were important you can try.
Sep 10, 2008 | Fortec Star Lifetime ULTRA
Koutech Systems Koutech KW-2103MS Memory Stick USB Card Reader/Writer, Retail (dsktkw2103ms) Logo
78 people viewed this question
Top Koutech Systems Televison & Video Experts
Are you a Koutech Systems Televison and Video Expert? Answer questions, earn points and help others
