Question about Norcent Technologies (RW531) CD-RW Burner
Function of the thumbwheel on front of CD-RW?
Does the thumbwheel control speed? Thanx
    Filmmaker:
    Uploaded 5 video answers.
  • 95 Answers
Hi althebutton
No the thumbwheel is for controlling the volume when playing music or some other media files from cd or Dvd. You need to connect the media cable at the back of your dvd/cd to your pins on your motherboard to work. You need to plug in your earphones or speakers into the small round socket next to the thumbwheel to hear any sound.
Posted on Sep 10, 2008
The power ic is burnt out so I need the number to replease it
The number of the IC is stamped right on the back of the unit. Can't miss it.
Aug 06, 2015 | RCA RCDM1001 Mini Audio System, Plays DVD,...
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
Won't recognize blank dvd
Chek wtat is written on front panel
If it DVD-RW it can record only DVD-R blank, if it + so only +R
or DVD-RAM. If it is DVD +/- RW or RAM it can record any disk.
Also chek the speed for you DVD and disk you using.
If you dvd maximum speed for recording is for example 2.7, 4, 8 you should use only DVD with max speed 2.7, 4, 8 or 1-8, 1-16 etc. So they should be labeled the same as you DVD
Good Luck
Jan 10, 2009 | Microsoft Windows XP Professional With...
Heater/ Air Conditioner Blower Motor
you should relist under lincoln continental, not refrigerators. If you have electronic temp control, you should not have a resister. You should have a bower motor speed controller.
here's info for 1996 system. I don't have 1995, sorry.
A/C Blower Motor Speed Control
The A/C blower motor speed control (19E624) is located under the A/C evaporator housing, to the left of the blower motor (18527).
  • The function of the A/C blower motor speed control is to convert low power signals from the EATC control assembly to a high current, variable ground feed for the blower motor.
  • A/C blower motor speed is infinitely variable and is controlled by the electronic control assembly software and A/C electronic door actuator motor position.
  • A delay function provides a gradual increase or decrease in blower motor speed under all conditions.
Blower Speed Override Thumbwheel
Rotate the blower speed override thumbwheel more than 10 degrees to turn OFF the AUTOMATIC blower indicator and provide manual control of the A/C blower motor speed.
  • The display will show FAN and a fan symbol.
  • Rotating the wheel fully down against its lower stop locks the blower motor (18527) at its lowest speed.
  • Rotating the wheel fully up against the stop, locks the blower motor at its highest speed.
Press the AUTOMATIC button to resume automatic A/C blower motor control and remove the FAN and fan symbol from the display window.
Jun 27, 2008 | Continental Fish File Refrigerator - 1 Row
Won"t see blank disc
given my experience with memorex blanks, i think that you should just switch to another brand....memorex made great tape....the cd blanks are another story. I recommend, if you can find them, FUJI blanks that are made in Japan; they have a reputation as some of the best.
May 30, 2008 | Teac DW 28E CD-RW/DVD-ROM Burner
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    CD writing
    What does it say on the front flap 52x? If 32x is as fast as it will go then thats it. In reaality whats all this fixation with speed best disks are written sloooow ;-)
    Jun 02, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
    Not reading dvds
    It says that it's a CD-RW drive- a CD-RW drive can't read/write DVD's, you need a DVD drive. You can pick one up for rather cheap from several online retailers - www.newegg.com www.tigerdirect.com etc.
    May 08, 2007 | Sony (CRX820E10X) CD-RW/DVD-ROM (Combo)...
    Norcent Technologies (RW531) CD-RW Burner Logo
    60 people viewed this question
    Top Norcent Technologies Computers & Internet Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Piyal Perera
    Piyal Perera
    Brandon Murphy
    Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
