Question about Spotlight Aquascape Water Proof LED 2-Watt Bullet for Water Gardens, Ponds, Fountains
3-light LED spotlight kit with remote solar panel #555-208
Hello, I bought a 3-light LED spotlight kit with a remote solar panel (for outdoor use) this summer and suddenly it kit working! What do I do? Thanks, Robert.
The Spotlight kit should still be under warranty for at least a year through the manufacturer. Check your manual and contact the manufacturer. The problem might be the seal which is allowing water in and therefore it needs to be replaced
Posted on Mar 24, 2009
Gu10 led light bulb are energy saving led Bulbs
Yes Gu10 led bulbs are energy saving led bulbs please check out the link below to know more about how much Gu10 led bulbs save energy
SHEERLED LED Bulbs SPOTLIGHT IN UK GU10 LED Lights IN UK
Sep 08, 2015 | brianydeal 3w Gu10 16 Color Rgb Led Light...
How much is the cost of Hampton bay lighting?
Depends on what lighting you are wanting. Home Improvement Made Easy with New Lower Prices Improve Repair home depot have prices for various hampton bay lighting models.
you can also find information here Hampton Bay Lighting Manuals
Mar 15, 2015 | Hampton Bay Outdoor Lighting. 1-Pack Solar...
Woods spotlight timer won't come on
Copy following links to identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://www.amazon.com/ACE-TRADING-COLEMAN-Spotlight-Digital/dp/B005PZIOVM
2) Woods spotlight timer appears to have mixed reviews on Amazon.
3) Cheap outdoor timers with photoeye are subject to frequent failure. Might be better to get ordinary spotlight yard stake, and plug that into analog wall timer like Woods 59204, or plug into outdoor remote control like Woods 32555.
4) I do not have instruction manual for this product. When you buy product, it probably has instruction sheet that will show operational parameters, and 1 year limited warranty.
5) This timer has 1 year limited warranty.
6) Try timer on different outlet.
Test outlet for at least 80% rated voltage.
Use circuit analyzer and test outlet for correct polarity and grounding.
7) I suggest buying timers at local store for easier returns. Simply buy another timer and return defect in new package. This action will give consumer warranty that extends beyond 1-year shown on package.
Dec 06, 2012 | Woods Hardware & Accessories
I"m working on a project to create a solar powered
Hello. Think I found the necessary information you require. Check out this link:
http://www.solarpowerwindenergy.org/2009/04/26/how-to-build-a-small-solar-circuit-wiring-diagrams/
There are schematics for each stage.
This one is a ladder diagram schematic only:
http://electroschematics.com/5988/outdoor-garden-solar-lights-circuit/
Good luck, and if this helps, rate it a four-thumbs up please. Thank You.
Apr 21, 2011 | Atlantic Water Gardens SINGLE LARGE LED...
I have a solar pump kit using an OASE Aquaflow 1500 submerged unit .The pump will spin when connected to a car battery but when attached to my solar panel which is producing 21 v on open circuit it will...
Hello Phil, what is the size of your solar panel? This pump draws 17 watts so, your panel must be 17 watts or greater. Remember a solar panel only puts out full power when in direct sunlight and facing the sun directly. You can read 21 volts but your amperage may not be full and this is why your pump is not running, not enough amps. I would recommend a minimum of a 20 watt panel.
Feb 14, 2011 | Plumbing
I have a Peak 2,500,000 candle power cordless rechargeable spotlight (PKCOTN) and it's not recharging. I tried to recharge on the wall outlet and connect the recharger on the bottom of the handle to the...
There is a panel on the back which opens up to expose a 120 v house current charger. You must use an extension cord (not supplied) which will fit in the narrow channel. The supplied 12 volt car charger plugs in to the bottom of the handle. A red LED lights up when either charger is used. The manual suggests 24 hours of charging before use. My condolences.
Oct 24, 2010 | Sport & Outdoor - Others
Outdoor umbrella with solar leds with switch, doesn't turn on
If you connect to solar panel for the lights to go on do the lights go out at night? If so, and the they do not light when hooked to the batteries then the batteries may have no charge and may also not be holding a charge. Put in new batteries to test.
Apr 26, 2010 | Solar 2-wire Pull Chain Light Switch For...
Power Output
Power supply AC 100-240 V, 50/60 Hz Power consumption Copy*1: Approx. 13 W
Standby*2: Approx. 2.2 W
OFF*3: Approx. 0.9 W
*1:When copying ISO/JIS-SCID N2 (printed by inkjet printer) on A4 size plain paper using default settings.
*2:When the scanning lamp is off. USB connection to PC.
*3:USB connection to PC.
Aug 06, 2009 | Canon Pixma MP480 All-In-One InkJet...
Spotlight Aquascape Water Proof LED 2-Watt Bullet for Water Gardens, Ponds, Fountains Logo
482 people viewed this question
Top Spotlight Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Spotlight Garden Expert? Answer questions, earn points and help others
