Question about Kirby Vacuums
I took my Kirby G4 outer covers off, vacuumed the inside to remove the dust and now it refuses to turn on. Is there some sort of redet switch?
    Novelist:
  • 97 Answers
I'm pasting this from another solution I posted. Hope it helps:
There are a few things to check:
There are safety switches mounted on the body of the machine designed to prevent the machine turning on when it is not fully assembled. Ensure that your bag unit is snapped completely into place, (with the rear of the emptor assembly nearly flush with the body of the machine,) and that the front nozzle assembly is mounted correctly.
Also check that the power cord (immediately aft of the bag unit,) is pushed completely into the machine.
If the switch does not feel responsive, it can either be that the little metal "pole" (for lack of a better description) is not attached to the main switch assembly correctly, which will require you to open the entire housing to check.
Those are the simple things to check, otherwise it may need a switch, cord, or motor replacement. Checking continuity on these items with a VOM will allow you to determine the cause.
-R
Posted on Sep 10, 2008
I have a kirby g4 how do i make it blow air (instead of suction) - I already attached the hose and the little attachment with a little ending to fit the inflating opening? thanks
Hi There,
Here's a step by step guide explaining what you have to do to change your Kirby from a vacuum into a blower:
Step 1. Make Sure That Your Kirby is Unplugged from the wall. Remove the front nozzle of the machine by lifting the housing that contains the headlight upwards. Now rotate the belt lifter from the green "Belt On" setting to the red "Belt Off" position:
Step 2. With the belt lifter turned to the red "Belt Off" setting, Turn the knob at the top of the bell shaped agitator housing to release the brush housing from the vacuum:
Step 3. Locate the attachment called the saftey cup that attaches on the Kirby in the exact same place as the brush housing did. This part does two things; Activates the safety switch to the left of the fan, and secondly covers the opening to the fan chamber to prevent anything from getting inside the fan housing and damaging it.
Step 4. Once you install the safety cup it is a good idea to check if the vacuum is working. If it is not (assuming it did work with the nozzle) - check if safety cup switch actuator isn't broken (see picture).
If it works then but it does not when you install the hose (next step) you will know that you did not turn the hose far enough.
Step 5. Take the bag off the Kirby. On the bigger end of the hose there is a line that you have to match with a little bump on the kirby fan housing (marked with red dots). Push the end of the hose over the Kirby exhaust as far as it can go.
Step 6. Turn this hose end clockwise (you may have to apply considerable force).
Step 7. It has to be turned far enough to press another safety switch that is on the unit just behind the exhaust neck.
Step 7. You are done and ready to use it as a blower. We would recommend turning it on outside. Hose may have some dust accumulated on the inside and it may blow a lot of dust in the first few seconds of use. Also shake the hose well while outside to loosen any dust/dirt accumulations on the inside.
    Be very careful when blowing dust out of computers or other electronics.
  1. Dirt from inside of the hose may damage components.
  2. Airflow is so strong that it may break circuit boards if they are not well mounted around the perimeter.
  3. Using Kirby a lot of static electricity may be generated that may cause circuit failure due to electrostatic discharge (harmless to people - deadly to electronics).
    NEVER operate blower with the nozzle on. There are 3 important reasons for that:
    1. Kirby is designed to have much higher RPM (Revolutions Per Minute) with the hose or safety cup so it will push more air than with the nozzle.
    2. If you use kirby as a blower with the nozzle - dust and dirt that is in the nozzle from vacuuming carpets and/or rugs will be blown into the air.
    3. If there is nothing (no nozzle no safety cup) Kirby vacuum simply will not turn on.
I really hope that the above instructions were helpful to you in converting your Kirby into a blower. If you have a question on any of the steps, please feel free to use the comment field to ask them, I'm always more then happy to answer any follow up questions you may have.
If this was helpful to you, please be so kind and rate the repair helpful, or by leaving feedback for me. This is really appreciated by the Fixya community when a repair was able to solve your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 12, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4D vacuum
hi, i can help you if you know how to use a VOM.
we will test for continuity.
tnx 4 using fixya,
drcool
Sep 16, 2008 | Kirby G4 Bagged Upright Vacuum
I need to remove the outer bag from my Kirby upright. The inner bag was not attached and there is mung everywhere.
In order to remove the outer jacket from your Kirby do the following.
Detach the top bag clip from the handle support. There is a plastic piece, just below the outer jacket, called the mini emptor. Turn it to the right to remove the entire bag assembly. Removing the outer jacket is dificult and even harder to put back on so this is what I would do.
Unzip the outer jacket as you were going to change the bag. Remove the paper bag. You will then see a long black tube, that has a 90 degree elbow at the top. That elbow is attached to the inside of the bag with a snap type strap. Remove the strap, then you will be able to move the tube, while you clean out the inside of the bag. When finished put everything back where it was.
Apr 28, 2010 | Kirby G4 Bagged Upright Vacuum
I have a G4 and the plastic at bottom of bag is cracked
Hi There,
Well sort of. For the G4, the bottom boot is sold with the internal fill tube that inside of the outer bag, where the paper bag connects. These two parts are sold complete as an assembly already put together. You'll just need to take off the strap at the bottom of the boot that holds the outer bag onto the boot. This strap is sometimes difficult, and sometimes it's easier to just purchase a new strap and install it.
Here are direct links to the parts that you'll need on our website:
Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S
And here's the bag strap that you may just want to purchase so you can just cut the old one off:
Kirby Vacuum Bag Clamp. Kirby Part # 196599S
If you have any questions about how to change this part out, please feel free to open a new repair, or just use the comment field here on Fixya. If you found this repair helpful, please follow the Fixya way and leave feedback for the repair. This is really appreciated when someone answers your repair questions, and is what keeps repair professionals continue to post free answers rather then just the paid ones. Thanks again,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Kirby G4 Bagged Upright Vacuum
I was vacuuming my car and the Kirby G4 just stopped
Greetings from GoVacuum,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
If the cord tested ok, then there are a few other things that may have gone bad. I'd be more then happy to try and help you diagnosis the Kirby further. Please just request a repair clarifiaction here on Fixya with further details.
If this helped you figure out the problem, please rate my repair as helpful. I really do appreciate it, thank you.
Chris J.
Mar 15, 2010 | Kirby G4 Bagged Upright Vacuum
I just notice when I went to change bag in my Kirby G4 that the whose inside was split open, which made all the dust fill up in the bag. How do I get a replacement part for this and what is that part...
You do not need a whole bag. The bag fill tube is replaceable. can be temp fixed with duct tape and new one installed at home. vacuum inside with another vac and you will be set to replace
Sep 07, 2009 | Kirby G4 Bagged Upright Vacuum
Dust smell when running g4 kirby
The dusty smell coming from my G4 finally drove me to search out the problem. As it turned out, the fill tube had cracked near the top of the mini emptor (the boot) and dust and crumbs were escaping from the tube and into the cloth bag. I tried to repair the split with duct tape and electrical tape, but to no avail. I finally gave up and ordered a new fill tube online for about $8. This took care of the problem, and the machine works like new with no more dusty smell.
May 28, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Vacuum "BOOT"?
The bottom part of the bag, which you referred to as a "Boot" is actually called a Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S. The part is only available to purchase with the fill tube assembly, this is the part that the disposable paper bag connects to inside the cloth outer bag.
Kirby has redesigned this fill tube, as the original design sometimes would cause the inner fill tube to crack. The Mini Em-Tor Fill Tube Assembly, part 199493S comes already assembled with the "boot" at the bottom, and the vacuum bag collar (the part the bag actually attaches to) at the top of it. You will need to remove the cloth outer bag from your old part, and put it onto the new "Boot". The cloth bag connects the "boot" with a special zip tie, which is Kirby Vacuum Bag Clamp. Kirby Part # 196599S. Where it is possible to remove the bag clamp without breaking it, I will warn you that this is no easy task. Spare yourself the aggravation of having to try and remove the clamp, and just cut the bag clamp with a knife or scissors.
You will also have to remove the top of the bag collar at the top of the cloth bag by releasing the fill tube from the inside of the cloth bag.
All of the parts are located on our website, www.govacuum.com. If you have any questions about the repair, you can get me on a live help, chat service located in the top right corner of our website. I'd be happy to walk you through this.
Thanks,
Chris Jones
GoVacuum.com
Sep 30, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4D vacuum
Could be the a/c cord, a problem with the noozle not pushing the saftey switch, the bag emptor(bottom of outer bag) isn't on the of the way and not engaging the other safety switch. The other is a problem with the motor.
Jun 28, 2008 | Kirby G4 Bagged Upright Vacuum
Cleaning Bag holder for Kirby G4
Take the ring from the bag re-move bag and put in a small bucket of water and let soak for about 1 hour and than remove rinse and let dry on a long slim container or counter.
Nov 27, 2007 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
