Question about CSi Speco PBM-30 2-Channel Amplifier
CSI Pa Amplifier with Am/Fm digital tuner p30a
When turned on the meter is pinned to the max and I have no PA working, I have tried taking all speaker wires off but unit acts the same.
  • 4,234 Answers
The output section has a problem which is detected by the circuitry and the entire unit is in "protect" mode. This mode effectively shuts off the output. If you don't have electronics repair experience, I'd suggest that you bring this unit to a service shop. Expect a parts cost in the $25-$45 range.
Dan
Posted on Sep 10, 2008
CB Plays out PA Speaker
it is possible that the PA speaker output is intended for a normal (unpowered, unamplified) speaker. Perhaps in your case the audio you hear from the PA speaker is only signal leakage from the PA Speaker connection.
To know.. connect a regular speaker to the PA speaker connector (any speaker, home audio, old car 6x9....). If the PA works and drives the temporary speaker OK, and you hear no CB receive, then the PA output is for a normal speaker, with leakage of CB audio.
It is just a guess, but easy to try.
May 04, 2014 | Radio Communications
CB in Receive Mode Plays Out the PA Speaker
no,its supposed to work that way so you can monitor it while you are outside your vehicle.
Are you following the user manual that came with the radio?
NB-ANL/CB/PA SWITCH: When the switch is in the NB/ANL position, the Noise Blanker (NB) and Automatic Noise Limiter (ANL) circuits are activated.
The Noise Blanker is very effective in eliminating repetitive impulse noise such as ignition interference. In the CB position, the PA function is disabled and the radio will transmit and receive on the speaker that is connected. In the PA position,
the radio acts as public address amplifier. Your voice will come out of the speaker that is plugged into the PA. SP. jack on the rear panel. The radio does not operate when you are in the PA mode.
When you plug a speaker into the ext. jack does it kill the radios internal speaker? It should until you unplug it; if not and you are following the about you may have a wiring issue with the jacks.
Galaxy dx 44hp, no am audio or mod ,fm & pa ok
Have you tried another mic. First guess microphone wire broke or broke solder for audio wire in mic jack at mic cord.
Mar 26, 2014 | Galaxy Radios DX-44HP Mobile Amateur Radio
Pa
per fcc rules (laws)? you cannot put an amp on a cb. max output 4 amps. you should be able to put a pa speaker using the pa output jack. take your radio back for warranty.
May 19, 2013 | Cobra 19 DX IV CB Radio
How do i get rid of the 60 cycle hum on our building PA speakers? We are using a Speco PBM-30 amp. A two-way radio audio is the feed.
That sounds like mains hum! Most amps have large electrolytic capacitors to take it out. They can go faulty and let it in. They are high value often around 2,200 or 4,700 UF or higher.
Mar 08, 2013 | CSi Speco PBM-30 2-Channel Amplifier
My cobra 29 turns on but i have no sound i can hear it key up and the meter swings speakerand mike are good could it be the finels
Are you sure its not on PA mode? And if the meter swings forwards its not a finale. It could be a bad soldier or IC chip. If you don't have it on PA to see if your IC chip is good take an external speaker plug it into your PA jack in the back turn on the PA switch and then key up the radio.Does it squeal or make any kind of noise if yes the the chip is good if no then there's your problem.If it is good Then its could be just a simple bad soldier.
Jul 15, 2012 | Cobra 29 LTD CB Radio
I only use the pa function.it doesn't always work.mic prob?when i switch to cb-no prob.
What type of PA speaker are you using? what OHM? and wattage.. A cb pa can only supply MAX 5watts into a pa speaker. It may be too big of speaker or bad speaker? if it works on cb.. wrong OHMS can make problems too..
Nov 15, 2011 | Radio Shack TRC-447 CB Radio
How do you bridg the pryamid pa 1000x power amplifier
you hook up the speaker the speaker neg on Right+ and pos on Left+
Sep 05, 2010 | Pyramid PA-1000X Stereo Amplifier - 1000W...
When we connected pa-6000a amp. to four speakers with impedence 19 ohm ( with matching tr), as in the manual , the temp. sensed on the body is very high while we put the amp. on fan ventilated panel
19 ohm - is very low :( - are you using a Impeandace meter to measure this -
Can you please email me the types of speakers and transformer used on the speakers
rghanem@bigpond.com
I am a services aget for Inter-M in Sydney Australia
Aug 06, 2010 | Inter-M PA-4000A Amplifier
CSi Speco PBM-30 2-Channel Amplifier Logo
315 people viewed this question
Top CSi Speco Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a CSi Speco Audio Player and Recorder Expert? Answer questions, earn points and help others
