I have a ksm2 braun coffee grinder I need a how to on blade replacement i have the new blade I have a KSM 1 (XXU) with the same problem. I have tried the solution that you suggested to tspitfirek09 , but was unable to get the shaft and the blade to disengage by applying a moderate amount of force and holding the blade still. Should I attempt to use a wrench of some kind to hold the blade in position while I engage the shaft with a screwdriver, or is there some other trick to dealing with this early model grinder? parksch
Hi sir
thats only to remove older blade[damaged] apply lubricant to loose it and leaving for some time try to shaft with screw drewer
"Should I attempt to use a wrench of some kind to hold the blade in position while I engage the shaft with a screwdriver"
that is the point. its a two side screw. and hecen you need to hold in one side when you turn on other side.
at this point you will need a wrench, and also screw driver for support...
let us know..
-->Unplug unit from power source. Remove lid and turn the unit upside-down.
Notice
a small slot on the bottom of the unit. Inside the slot is a visible
screw that you can control the movement of the motor. Insert a
screwdriver into the screw head. By doing this you are now holding the
motor stationary.While you have the motor stationary, remove the damaged blade by turning it counter-clockwise. It should unscrew quite easily.
Install the new blade by turning it clockwise, make sure that you are still holding the motor stationary with the screwdriver.
Notice
motor stationary.
Replacement Instructions
Notice
hope this initial info helps you..
-or just let me know if you need more assistance.
regards
micro
