Question about Technics Audio Players & Recorders
Technics1210, the treble and midrange is very distorted, tried different needles and swapped channels but other deck still sounds crisp and sharp, been told it could be the leads????? from dan h.
Hi there, yes there's a chance it is ur leads that are the problem.
Have you tried other needles/headshells in the problem deck?
A bad headshell connection can also possibly be to blame.
Firstly i would suggest that u unscrew the headshell and have a close look into the end of the tonarm.
The 4 little contacts in there are supposed to be sprung a little, check that these aren't "stuck". Sometimes they get stuck all the way pushed in (usually a result of dirt, age, or most likely - headshell has been overtightened).
also check they are clean, if not use a cotten bud to carfully clean them.
Not the problem? try checking:
- Check the headshell contacts are clean, i find buffing the headshell contacts by carefully and vigorusly rubbing the base of the headshell on my trouser leg (or a dry duster streched over my leg) an effective way to get them nice n shiny :-)
- Check the 4 little wires connecting the catridge to the headshell arein good nik + connected properly (google search if u need to check which way they go)
-if none of these help then I would suggest checking with a continuity tester/multi-meter from each of the tonearm springy contacts to the phono plugs. Each spring contact should bell through to one of the phono connectors contacts, check all 4 wires bell through, failing this put ur meter on ohms and repeat this step checking the resistance when belling them out, find 1 with a high resistance then thats your problem.
Hope this helped
:-) Dj E-mission
Posted on Sep 10, 2008
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
One of my decks sound louder than the other
I'd say the cartridge is getting tired. Swap the head shells with carts and test. Cheers john. Styluscity
Nov 27, 2012 | Technics SL-1210 Turntable
What are the best settings for bass , treble and mid in order to get the best sound
There are no hard and fast rules for setting Bass, Midrange and Treble on your radio. Depending on the type of music you are listening to with your radio, it can / will determine your sound settings. To attempt to set the sound settings on your radio, select the sound settings and set all of them to 0. ( Bass,mid,treble ), then start playing your usual music. With the music playing move the treble setting in single incriments 1,2,3,4 and so. A comfortable setting is usually a 5 out of a total number of 6. Then move over to Midrange and repeat process. A 4-5 out of 6 is usually comfortable. Finally comes the Bass. You do not want to overpower your speakers with too much bass as this will damage them over time. Repeat the usual process and listen carfully for any baffling or distortion as you move through the numbers. A comfortable bass setting is usually 2-4 out of 6. Again I must stress that there is no hard and fast rule for settings. It boils down to the type of music, and what your ears tells you sounds good. What sounds good to me might not be enough for you, or vice versa. I hope this helps! Cheers!
Mar 30, 2011 | Pioneer DEH-4300UB Car CD/ MP3 Player
The sound is distorted and overwhelmed by static
Depends what the real problem is.
Is it related to certain sources only - try new or reseated cables,swap it to a different input; single channel - swap to isolate; or certain controls that have become noisy? A shop might be able to get some tuner cleaner into them.
Mar 12, 2010 | Panasonic SA-XR25 Receiver
Technics Tape Deck RS-M227X. VU needles jump to the maximum right
More than likely the pre-amp IC has failed! Trace the wires from the VU meters back they should locate the source of the problem. Remember it will be something common to both channels!
Oct 30, 2009 | Audio Players & Recorders
How do i fix my bass and treble on my deck
If you are having distorted or muffled sound from your deck then this could be caused by either 1)poor settings 2) bad output amplifier or 3) blown speakers, inspect 1 and 3, if ok then is 2. hope this helps.
Sep 30, 2009 | Alpine CDA-9831 CD Player
Numark tt200 one channel dropping out on playback
You need to repair the internal RIAA pre amp.
Oct 28, 2017 | Audio Technica USB Turntable
Squier champ 15
Hi lumberman597
The cool thing about guitar amps is that you can mess with the knobs until you find the sound that you like. There is no particular way to use it, just try to find a tone that suits you. Start with gain controls down and tone knobs at 12o'clock. Turn up the gain(one at a time) to get distortion and more sustain to your sound. Turn the distortion up midrange down and treble up for metal sounds, more bass and midrange for bluesy sounds. just play around with it and you will see what I mean. Here is a guide from Fender on how to setup your guitar. If you are not sure, a good guitar tech can make any old axe feel and sound great with a good setup
unfortunately, Fender do not have an electronic copy of your owners manual to download, but you can buy one for $5 direct from them here It is only a 1 page manual.... so you will get more from just messing with it.
Musicians spend there whole lives tuning and tweaking knobs to get the sound they are looking for. It wont take you long to start doing the same.:)
Jul 22, 2008 | Fender Audio Players & Recorders
Center Speaker sound just not right
If the optical cable was bad, the sound would be distorted period. The optical cable (whether coax or fiber) just simply carries the coded audio to the receiver which in turn decodes it. I have never heard of a signal just screwing up the center channel, and I've been at this better than 30 years. Not to say it's impossible, but very unlikely.
Did you try swapping speakers? Move the left one to the center and the center to the left. Does the center remain "distorted"? Does the left become "distorted"? If the center remains distorted, the receiver's center channel has something wrong with it. If the left is distorted, the speaker has a problem.
For the future. it is un-neceaasy to purchase expensive cables. In fact it could make things worse. The claim to fame of most expensive cable manufacturers is the gold plating on the connectors. Unless the bioth sides have gold plating (receiver, cable box) this actually creates a capacitive reactance between the different metal types. FYI-capacitive and inductive capacitances are the basis for designeing cross-overs, filters, etc. So basically, an undesired filtering effect is created. This applies to speaker cables, audio, video, etc....
Feb 15, 2008 | Harman Kardon AVR 635 Receiver
118 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
