Question about ViewSonic E70f 17" CRT Monitor
No display, clipping sound appear
My E70f monitor has no display and the clipping sound appeared. All of the AC/DC voltages appear. What happened?
  • CF Thor Sep 10, 2008
    What are the bad components that caused this problem? If it is short, then what could it be?
    By the way, where is that clipping sound come from? I am trying to fix it
  • ViewSonic Master
  • 19,396 Answers
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Posted on Sep 10, 2008
  • Ginko
    Ginko Sep 10, 2008
    There are like 3000 components inside a CRT screen, you need the service manual ($30) and a tester, then you follow diagrams from service manual to find the fault.
  • Ginko
    Ginko Sep 10, 2008
    The clipping sound comes from a relay mounted on the board, called the safety switch, and you cannot fix it , because that is the effect of a different fault, not the cause.
    Servicing electronics can lead to hazard and serious injuries if you do not know what you are doing.
My Monitor ViewSonic E70fSB 17" Monitor is working
Causes of OSD LOCK
1. The monitor is incompartible with the system unit, especially for newer version units versus older monitors
2.Older monitors display attempting to much up to the improved definition functions of newer system units display an operating system malfunction, interpreted as monitor malfunction instead. OPERATING SYSTEM DISPLAY MALFUNCTION
hardware checks
1. consider changing the graphic card on the system unit after attempting to adjust the appearance settings on the desktop once the computer is powered on.
2.Once changing the graphics card on an old system unit, consider changing the processing chip for reasons of achieving peak performance of the new part installed.
3. Once the fxing of the parts are complete, the monitor would continue to display OSD requiring entire system restart or book. after which, adjusting the appearance setting that should by which time display new list capacities due to the new device changes
Dec 06, 2010 | ViewSonic E70f 17" CRT Monitor
Viewsonic E70f monitor goes standby by message OFF MODE IN 5SEC
off mode in 5 sec,problem represents that the data cable is not properly connected or the monitor is unable to recognize the connection once check your key board lights above the num pad when you switch on the PC if the lights appear . Then the power supply is not provided to only the monitor unplug the data cable and plug it again properly,even if doesnt solve your problem just shake the data cable receiver pin located to the back of the monitor.
If the lights on the keyboard does not appear the problem is within the cabinet it may occur due to the dust too,so clean it properly , using a hair drier for blowing the dust is better.
Hope this would solve your problem.
Nov 03, 2010 | ViewSonic E70f 17" CRT Monitor
In my View sonic CRT monitor E71f 17",there is a curve appearing on the upper side of the screen and there is some space between the display and the screen, please help. thanks
It's time to responsibly recycle your old CRT monitor, and spend about $100 to buy a new 17" or 19" LCD screen, rather than spending any money at a qualified TV/video technician, trying to trouble-shoot the problem.
Oct 17, 2010 | ViewSonic E70f 17" CRT Monitor
Power failure issues
The specs for this monitor is a 60 Watt, 12 Volt, 5 Amp power adapter. The voltage must be the same. You can always get an adapter with a higher Amperage rating, but never get one with less, as this can overheat the adapter and damage it. I was not able to locate specs on whether the voltage to the monitor is DC or AC... most are DC. If this is the case, the observe the polarity at the monitor. Power adapters have a positive and a negative... center and outer contact, Make sure that the power adapter matches that of the monitor, else it will not work.
Sep 26, 2009 | Balance CM2017 17" Monitor
Hello, my iiyama routinely displays the Contrast menu and won't go away. I can click the Exit button on the monitor which only temporarily removes it.
15sunnybank, Did you try swapping it to a different PC to make sure that the problem is in the monitor and NOT in your PC? Sometimes when the DC voltages (which power up the electronic circuits in these LCD displays) become marginal due to age of unit, then weird stuff like unexpected/uncalled images/menu's could appear. First have a TECH type friend verify if all dc voltages are within specification. One more thing!! Don't post here without letting us know some history on the unit you hope to get help with. Age of unit?? Approx total # of "on" hours??
What happens if you put a 10 inch fan blowing cool air into the monitor?
I'm louie12fix on fixya or lmistyrel @aol.com Bye for now
Sep 25, 2009 | iiyama ProLite H481S (Black) 19 inch LCD...
When i on the PC this message appears on the screen :OSD LOCK. the type of the monitor i am using is ViewSonic E70f 17" CRT...
To enable or disable the OSD lock feature, press and hold the 1 and the up arrow for 10 seconds.
Jun 03, 2009 | ViewSonic E70f 17" CRT Monitor
ViewSonic E70f 17" CRT pincushion changed itsself continously
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
May 22, 2008 | ViewSonic E70f 17" CRT Monitor
ViewSonic E70f 17" CRT Monitor Logo
395 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
