Question about Samsung Televison & Video
I have a samsung tv model # ln52a75r1fxza 30 days old, also a verizon Hd box wen i set it up with the HDMI wire HDMI to HDMI the picture is'nt Clear if i use rgb to rgb its OK I called Verizon they tell me its a samsung issue with this Model Vv love the TV but would like the HDMI to work Thanks aholden1@verizon.net
tvtek
  • 1284 Answers
SOURCE: HD input
On the Magnavox projections, only one of the inputs supports hight than 480p input IE: 720p, 1080i. Make sure it is the correct input.
Posted on Dec 19, 2007
SOURCE: Verizon FIOS Motorola 6200-2 HD box remote freezes
i'm a verizon employee currently working at a customer's house. just swapped out 3rd 6200 stb, the channels will seemingly change on their own(scrolling) after pressing the remote just a few times. the root of the problem is that the remote is not responding to the stb in the first place properly. all i can figure is that there is some type of ir interference. i've placed the remote 1" from the stb and the same problem exists. it's not the box and the remote is brand new, tried 3 remotes as well. there is something going on in the atmosphere around the box - in or outside the custmer's house. they were on vacation and when they came back this is the trouble they were having. i don't have an answer, just some type of possibilities. there is a power transformer outside on a pole approx. 100' from the house and we had bad storm related issues in the past week. i know it's a stretch, but you never know. could be surround sound/ stereo equipment generating some kind of field??????????? good luck.
Posted on Aug 10, 2008
mistersony
  • 320 Answers
SOURCE: Sony HDTV flat - no picture with HDMI cable and Verizon FIOS box
Probably a handshake problem with the cable box. It is common for cable boxes to have HDMI handshake problems. Hook the box up using the component cables and you should be fine
Posted on Oct 18, 2008
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
  • 14 Answers
SOURCE: I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
Posted on Apr 01, 2009
No picture on Samsung HP-R5052
Just a couple of things to try:
You say you tried another cable box and a roku. Are you using the same cables? Are you using hdmi, component or coax cables? Could be a bad wire. True high def tv 1080 requires an hdmi cable for the best picture. The next best choice is the component cable. This is a triple cable with red, green, & blue and provides 720 resolution. The least quality is the coax wire which will only provide low def standard quality picture. Sometimes people hook up 1, 2, or all 3 of these choices not knowing what it all means. If thats the case with your tv it may just be a matter of selecting the correct input on your tv with your remote. On your samsung remote there should be a button for input. Try pushing that button and make sure it's set to hdmi or component, whichever your using. If none of this, is it possible the plasma tv itself is defective?
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
Samsung lcd 720 ln32b360 doesn't fill screen in 16:9 mode. Went through tv setup, connected it to hd box (verizon Fios) plays all HD channels but does not fill screen as it should. TV is connected to set...
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Jan 07, 2010 | Samsung LN32B360 32 in. LCD HDTV
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
I have hd picture but no sound, tv says hdmi audio unavailable
I called Verizon and exchanged my STB from a QIP 6416 to a QIP 7216 and it solved the HDMI audio problem. This looks like the fix.
Apr 05, 2009 | HP PL4260N 42 in. Plasma HDTV
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
"Not supported Mode" message
Hook up the component cables on the tv and the dtv box
go to set up on the menu select HDTV or display and deselect all of the 480i and 480p and in some cases also the 720 and only select 1080i to be display. you can then hook up your hdmi cable again and it shoud be supported. Let me know if that works.
Nov 18, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Screen goes blank
This set has a factory upgrade for HDMI problems like yours and it also fixes another problem for intermitent sound in the HDMI mode. This model is still under warranty. Call: 1-800-SAMSUNG To find a local servicer in your area.
Jul 02, 2007 | Samsung LN-T4665F 46 in. LCD Television
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
Televison & Video Logo
Henry  Thomas
Henry Thomas
