Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Schematics I went to replace the belt, and when I put it back on I noticed the silver pulley that the brush belt goes on has came unattached from the red piece by the motor belt. It is one peice. I can order a new pump, but I need the schematics so I can replace the pump. http://www.vacuums24x7.com/bistclpa.html How can I enlarge this so i can read it?
  • Mary Gentry Sep 11, 2008
    Thank you and yes, Please send me the pic.
    mary0169@yahoo.com
  • Anonymous Oct 17, 2008
    Will someone post a high resolution schematic pic to share with everyone?
    President:
  • 1,673 Answers
Well you can right click the picture and save it to your desktop, I did it, but it was alittle blurry. But if this doesn't work for you, post me your email addy and I can send you a better picture. But take the top off, there are 6 screws, 3 on each side, remove the cap for the spinner, remember how the spinned and filter go back on before you re-install the cap, turn the smart mix valve half way so the piston doesn't come off, then pull the top off. replace the pump and remember which line goes where, make sure before putting the top back on that all lines are routed so as not to pinch. Start to put the top on, just before pushing it down, turn the smart mix vale to water only, then push it all of the way down. The cap for the spinned doesn't have to be real tight, sometimes you have to leave it just hand tight. Then turn it over and hook up the cogged belt again to the brush roll.
Posted on Sep 10, 2008
  • Lauren Junge
    Lauren Junge Sep 11, 2008
    Ok, the pix's are on the way, good luck.
How do I replace drive belt
turn the vacuum over,were u are looking that the bottom of it there is a plate that covers the brushes and pulley for the motor remove this plate should be three to four screws the plate will lifted from the back it has two hooks on the front,,after u have done this u take the brush roller out by pulling straight up on it notice how it comes out it should have hexagon ends on it it will side back in the same way,,now take the belt off clean off any debris if necessary put the new belt back on the motor pulley and roller brush, side roller brush back in(this might be a little hard scene u have the new belt on)and be sure that ends of the roller brush sets all the way down on the sides,then put back the plate start from the front putting the hooks on first on the front then replacing the screws, u shuold be good to go, Hope this was helpful
Apr 06, 2011 | Hoover U6630-900 WindTunnel Bagless...
Is it necessary to take the vacuum cleaner apart to change the belt on a Hoover Wind Tunnel Self Propelled vacuum cleaner, model UI6460-900? If so, how is that done? If not, how do you get the belt on...
To change the belts, make sure the vacuum is not plugged in. Lay it upside down and remove the screws holding the bottom plate on. Remove the bottom plate, pull the brush roll out noting how the belt goes so you will know how to put it back together. Especially how it goes around the idler pulley. Remove both belts, replace both belts, install the V belt onto the transmission first then around the brush roll and put the brush roll in place. Install the flat belt around the motor shaft and then onto the transmission pulley.
Feb 06, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
I need help replacing my belt
Just changed mine. I have a Turbo Force 6585. Flip it over and press with your fingers on clip #s 2,3 and 4 (This releases the cover over the roller brush - The clip locations are labeled on the plastic cover). Remove the cover - this will expose the brush , belt and drive motor spindle. Pull the roller straight out (note one side of the roller has a "square peg" - its pretty obvious but you need to align it when replacing. Remove the belt and replace the new one over the silver motor spindle first and then the roller. You will see the area or Pulley (it is part of the roller brush itself) to put it on it is fairly obvious where it goes. Use the roller to stretch the belt and insert the roller back in and replace the cover.
Note; There have been several complaints about belts breaking prematurely on these models - I used a Homecare No. 1145 that is made to fit Panasonic Upright, Belt type UB / UB8 - This belt is about an 1/8 longer (much less tension) than the supplied one and it hasn't broken yet - Considering the factory supplied belt broke in 3 uses, I really don't care what Bissell recomends as this has been a common complaint with this mode on forums. Hope this helps
Apr 12, 2010 | Bissell 6594 PowerForce Bagless Upright...
The brushes aren't spinning
The brushes are belt drive by a belt. The belt is probably broken. You can purchase a new belt at a local discount store and replace it. You won't find anything that looks like a pulley, it'll just be a bare round metal portion of the brush assembly that is located at one end. The motor end will look similar.
Feb 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Installing a belt
1. Unplug the vacuum
2. Take the bottom cover over the brush off by removing the 3 screws
3. Switch the brush roll control lever to bare floor
4. Take the roller brush out
5. Put the belt around the small pulley from the motor
6. As you are putting the roller brush back in put the belt around the space on the roller brush - center the belt on that space - THE BELT WILL NOT BE TIGHT BUT THAT'S NORMAL
7. Reinstall the bottom cover with the 3 screws
THE BELT DOES NOT GO AROUND THE SILVER PULLEY CONNECTED TO THE BRUSH ROLL CONTROL LEVER
Dec 27, 2008 | Vacuums
Brushes won't turn
Sounds like you have broken belt. I had the same thing happen, Got replacement belts, but can't figure out how to get the smaller belt back on. There two larger belts - one on each end of the brushes under the clear plastic covers. On the left side there a single silver metal gear, but nothing to hook up the other end of the small belt to drive the brushes. If you take yours apart let me know how to hook up the smaller belt.
Thanks,
David Wood
Aug 13, 2008 | Bissell 9200 Upright Vacuum
Motor shaft/Brush pulley
It cant be repaired you have to order a new pump @http://www.vacuums24x7.com/bistclpa.html
Bi-010-7185 $23.99 or bring it in for repair.
Has anyone tried liquid steel filler?
Mar 19, 2008 | Bissell 8910 ProHeat Clear View Upright...
Changing belts
Turn vac over, remove the 4 screws holding the bottom plate covering the brush roll. There are 2 belts, one is a V belt ( 38528034) for the brush roll, the other is a flat belt (38528035) that goes from the larger pulley and the motor shat, put it on the motor shaft then stretch it to go over the pulley.
Jan 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
254 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
