Question about VIA C3M266-L Motherboard
Keyboard beeb hello.. when i start the computer ,its tell me the keyboard not found and tone continue"beeb"
  • 641 Answers
Check first keyboard's connection to your PC. If you are using a windows OS : - Make a right click on "my computer" - Another right click on "properties" On the system properties screen: - make a left click on "hardware" - Another left click on "Device manager" On the device manager screen : - Look for the "keyboard" - Make a left click on it. - See if you have there a keyboard definition and double click on it Under the "Generl" tab look for the device status. Should be "This device is working properly" - Left click on the "Driver" tab and run the "update driver" process If problem still exist, run the "Roll back driver" process
Posted on Apr 06, 2006
  • Dov Dror Apr 06, 2006
    Did you solved the problem and how ?
Hello sir i have scooter mobility pride 3 wheel i but new battery than 1 day after i wash scooter the scooter not drive gave beeb 7 time than stop now a lot beeb if you can please tell me what to do
hi, well that's a 70amp rhino controller, beeb seven normally amounts to a throttle pot (wig wag ) fault... i suggest you make sure there are no water around the connector plugs going into the controller , please remove one battery lead before proceeding..I do offer free controller testing and have swap out units if required for as little as £40...
Jan 31, 2016 | Pride Health & Beauty
One continues beeb!
Take everything off of it that you can. No cables for keboard, mouse or monitor and try it. If it beeps then there is an issue with the internal components. If it works put the monitor on and see, then the keyboard, then the mouse and you can figure out what the issue is that way. If it still beeps then you are going to have to take the covers off and take out the RAM chips and the cards and any connections to the drives. Then try and see and put things back one at a time till you figure out what is causing the problem.
Feb 03, 2014 | Gateway Sx2370-Ur10p Desktop Black
The dial tone is going beeb, beeb,beeb,beeb,but the phone is working ok,its like there is messages but it does not have answering machine
You may be subscribed to a voicemail system provided your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 15, 2012 | Lands Phones
When I turn on my acer, a loud beeping sound continues until I shut it off. What happened?
Those beeping noises are called, simply enough, a Beep Code. The continuous tone usually means that your computer has a bad memory stick (or multiple bad sticks). They will need to be replaced.
If the computer is under 1 year old, you can get this done for free under your manufacturer's warranty. Otherwise, the new memory will cost usually a minimum of $50, depending on where you buy it.
Mar 09, 2011 | Acer Aspire One PC Notebook
My neo basic B2165 laptop keeps long constant error tone while turn on and freeze on booting(and error tone doesnt stop), you have to press del or @ keys to stop error tone and continue to boot up and...
Since you have reinstalled the OS and it didn't fix the problem. It most likely your computer having one or more hardware failure. You need to check each of your computer component to find where is the problem.
Feb 28, 2011 | Computers & Internet
I get 1 beeb followed by 3 beebs followed by 2 beebs then nothng happens dell diemension 8400
Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3) consists of one beep, a burst of three beeps. This beep code tells you that the computer encountered a memory problem
you need to reseat your memmry modules just remove them and place them back in the same or a diffrant slot this cold be loose connection by connecting them again you fix it
------------------------------------------------------------ if you dnt know abt it see this it will help you
Apr 10, 2010 | Dell Dimension 8400 PC Desktop
My pc won't start after I reset the cmos it only says beeb all the time over and over again. i can't find the manual to find out why it says beeb. the motherborad name is: ca63-sn rev. a1
The beeb you are hearing is a code being sent by the motherboard specifically the chipset on the motherboard. Count the beeps and go to the maufacture web site and look up the BIOS beep code that the manufacture uses. It will tell you what is wrong with the PC motherboard. My guess is obviously a hardware issue possibly the power supply is not working correctly and the motherboard is shutting down to protect itself. Good luck
Robert Matheson
Jan 03, 2009 | Computers & Internet
Acer laptop
Pop the enter key off (be gentle), then take a Q-tip with alcohol (rubbing not drinking) and clean the connector and the rubber riser. If the problem persists, the you will have to replace the keyboard.
Jun 30, 2008 | Acer Aspire 5610-4648 Notebook
Problem withPanasonic phone
Unplug the power supply to the phone, wait 1 minute and plug it in again
Mar 05, 2008 | Lands Phones
VIA C3M266-L Motherboard Logo
51 people viewed this question
Top VIA Computers & Internet Experts
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
