Question about Refrigerators
Ice Dispenser issues
The dispenser is not working, same problem as posted on Aug 27 with a same problem post by me on Sept 9, 2008.
I have replaced the part # WR55X10415, with a new one that I ordered from GE, but still having the same problem.
What other hints could you provide to resolve this issue.
Thanks in advance for your assitance.
  • 3 more comments
  • twparker Sep 11, 2008
    I have a GE PSS26LG refigerator, which has a thur door water, ice dispenser. The dispenser unit appears to have power, as the LED lights will light up for the user selected action. But once you depress the cup lever the LED lights will go off for a few seconds then light back up. The unit will not disperse ice or water, and the dispenser light will not come on during the selected action or just when you press for the light only to come on. The bulb appears to be in fine shape, no missing fillement (not blown). The lock panel selection appears to work, the open door alarm appears to be working.
    I have replaced the lite touch panel GE part: WR55X10415 with a new one I ordered from GE, still having the same issues as with the prior panel. I am currently waiting for GE to send another replacement to verify I did not receive a faulty new panel. Should the new replacement panel have the same issues as the two prior, I will be at a loss as to the problem.
    Could the problem be with the rocker switch that makes contact with the cup dispenser? I do not belive the water control value is acting up as this should not impact the ice dispenser, the only common control between the water and ice dispenser would be the cup lever/rocker swith, and of course the lite touch panel.
    In addition, I have cycle down the refig, (unpluged the unit for a time, then powered), this action done thinking maybe static interered with the lite touch panel. No such luck, unit still acting up.
    Ok, for this model PSS26LGRD BB, the wires are located in the bottom hinge. and this appears to be where the problem is located.
    The wires from the door panel to the plug at bottom seem fine, but there is apparent problem within the plug itself. one wire appears to have been arching as the plug appears corroded, and while disassembling, I freely pulled one wire out. I belive this is the problem, the single wire correded and broke free from the contact, but still in the plug base, the panels apparent come and go, was due to the wire siding in and out, thus wire contact was hit or miss. As this plug is shot, I am going to do a hard wire, bypassing the plug, if this was the problem, then this should resove while I order a new cord assembly and plug
  • amonc Mar 05, 2009
    I have the same problem. my fridge is the ge ps26sgrdss. just replaced wr55x10415 doesn't allow ice to come out. any other solutions?
  • Pete350 Apr 19, 2009
    How do I remove the plastic cover (outside freezer door) on my Whirlpool S/S #ED25CQ so that I can replace the dispenser levers? Thanks! Pete
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    When I click on "twparker" the site does not show your posts. I have posted over 100 solutions in the past couple of weeks and the site does not list them by dates, user names, or model. Can you add additional info?
  • 1,543 Answers
OK, I'll take a stab at this one. Sounds like a poor electrical connection. If you changed the WR55x10415 interface you would have found any multi terminal plugs that were not fully seated there, so next I would look at the wires passing through the hinge at the top of the freezer door (under the plastic hinge cover). I don't think you have an issue with the switch as then you would probably not get any reaction when you depressed the dispenser. Note: there are a few more letters in the model number. You should be able to find the full model and serial number sticker inside the fresh foods section on the upper side wall or ceiling.
Posted on Sep 11, 2008
Ice dispenser and water dispenser does not stop after use.
Hello Junhee, thank you for your post!
From what you have described your ice and water dispenser on your Frigidaire refrigerator continue to dispense after being used. This could be a possible issue with your dispenser or the switch inside of the dispenser. I would recommend looking over the dispenser to assure there is no visible damage done to your dispenser. You may need to have a technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Dec 19, 2015 | Frigidaire Refrigerators
How to change the light bulb in the outside ice/water dispenser
Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
The light on the outside door (where the ice/water dispenser is) won't turn off. It is dimmer than when you hit the 'light' button, but it stays on constantly when the door is shut. The 'light' button works and turns the bulb brighter, but when you turn it off, it just dims and doesn't go out. The light shuts off when the door is open and turns back on when its closed. Model Number MSD2456GEB
Posted by linsdesk on Aug 31, 2011
Aparajita Batabyal
  • 3,513 Answers
Re: The light on the outside door (where the ice/water...
Hi
Reprogramming your refrigerator to only light up when the dispenser is in use saves energy and keepsyour house darker at night. The light is controlled using the buttons above the water dispenser mechanism.Press and hold the "Lock" or "Lock Controls" button for three seconds to activate the controls if they currently are locked.Tap the "Light" button to switch off the light.Press and hold the "Lock" button for another three seconds to lock the controls from further changes. The light now only comes on when the dispenser is active.
If the above procedure won't work then this will be the cause of a faulty switch. This light switch is an integrated part of the dispenser control circuit board. This will require you, or your service tech to replace the entire dispenser/ice maker control board. It will be located just behind the dispenser fascia, mounted on a bracket. the actual light switch circuit is mounted on this board.
Try this procedure:-
Shutdown the unit for five minutes. Simply unplug the unit for this length of time. This will reset the board, and possibly, fix this fault if it is not to severe. If the shutdown dose not correct the switch action, simply replace the dispenser/switch control circuit board.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Jul 25, 2015 | Maytag Refrigerators
GE Profile refrigerator model PFSS6KW/PFSF6PKW not making ice.
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Feb 22, 2015 | GE Refrigerators
Ge psc23ng no ice
  1. Dispenser switch
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Search Over 2 1 Million Appliance Parts
Sep 07, 2014 | GE Profile PSI23SGR Arctica¿...
GE profile refrigerator ice maker not working
  1. Dispenser switch
  1. Door switch
  1. Dispenser switch
  1. Door switch
Water dispenser doesn't work
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Why is my GE Profile Refrigerator ice maker no longer dispensing ice?
  1. Dispenser switch
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Water dispenser not working
Should have posted the model number, based on your issue, it sounds like a intermittent water valve, should be replaced,a bad dispenser switch, or a faulty relay on the main board.
Apr 28, 2014 | GE Refrigerators
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
No ice or water from dispensers
Womers, make sure there is not a lock-out on the dispensor panel. If there is, hold it in for 5 seconds and see if the dispensors come alive. Because both water and ice are not working, I would think you have a dispenser board issue. Catriver..post back.
Sep 26, 2006 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
399 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
