Question about Epson Stylus 680 InkJet Color Printer
Printer the red light keeps coming on and it wont print
  • Anonymous Dec 04, 2008
    red light remains constant and the green light is flashing
  • alisnik Jan 07, 2009
    I have the same problem.
    When the printer is turned on the top red button comes on and stays on and it will not print.
    I have changed the ink cartridge and given it the usual thump but no good.
    Any help greatly received
  • Epson Master
  • 691 Answers
Add a bit more detail and I may be able to help you.
Under what situation does the light come on.
Is it a constant light or a flashing one.
Does it happen at the same point every time (i.e. startup, when beginning a print job, half way through a print job etc) or is it intermittent.
Have you had any other problems recently like a paper jam, have you changed anything (ink for instance).
Give as much detail as possible please.
Posted on Sep 10, 2008
5 Suggested Answers
flopez
  • 161 Answers
SOURCE: red light flashing
You need a new toner bottle.
Posted on Nov 02, 2007
MyTechGuru
  • 93 Answers
SOURCE: the power light keeps blinking and the printer wont print
Here is the solution on Hp web site for Blinking light
Click Here
Posted on Dec 16, 2008
  • 254 Answers
SOURCE: GReen light keeps flashing and my printer wont print
two options
1)either any of the printer cartridge is faulty.remove the cartridge and clean it with tissue paper.
2)or the printouts are pending in printque.delete all the printouts and then try .
any one of the above options will solve the problem.
if cleaning the cartridge does not solve that means it faulty so replacement of cartridge is necessary.
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: we changed the ink and the red light and green
Some times you need to find the epson tools that comes on the CD to reset the printer. If you have upgraded the computer you may need to update your drivers at the epson sight.
Once you have opened the epson tools try cleaning the print heads.
then it should reset the inking system to default and read the new cartridges. If this doesn't work try shutting down the printer and removing the ink cartridges, restart the printer and allow it to find no cartridges the go through the process of reloading the ink cartridges again and cycle the printer.
If this doesn't work you may need to try and find a cleaning cartridge for the print heads. Since the printers always check to see if ink is getting to the print heads if there is no ink flow it will always come up like there are no ink cartridges installed.
Hope this helps
Make sure paper is in properly they can be very picky about that.
Try turning it off wait three minutes and turn back on.
Then
Push Paper refill button Wait for cycle and see if paper light stays off if so...
Push the ink button
Posted on Sep 18, 2009
Red light flasing and printer wont print
Remove all the Cables keep pressing the power button. this is easy way to remove all the power from the printer. Make sure there is no Paper jam and roller is clean to your best extent.( Dont try to be smart her ). Remove the ink toners. reseat the cables. Connect to Computer. Power on teh Computer First. Now poer on the Printer.
Let it ask for the Ink Cardridge. It shall come to Normal behaviour and PRINT. Let me know if you need explainations. I will check the comments. make sure you rate this solution. to get in touch.
Happy Printing.
Sep 12, 2010 | Epson Stylus NX100 InkJet Printer
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
May 15, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My printer will not print. The red light comes
My printer will not print. The red light comes on, but there is no paper stuck anywhere. The toner light comes on, but when it did print yesterday, it looked fine. Please let me know what I need to check. Thank you,
Feb 15, 2010 | Brother HL 5140 Laser Printer
Lanier 5645 cannot reset printer red button just keeps coming on
when you press the 'red' button, it probably says 'paper mismatch, or load "XXX" paper, and you can override it by selecting one of your paper trays manually? It is likely a "legal size document' and you don't have legal size paper loaded, or something along those lines. Try printing the document after manually selecting the paper size/tray (turning off auto paper select) in your printer preferences dialog box on your PC first.
Mar 02, 2009 | Lanier Office Equipment & Supplies
Will not switch on and both red lights keep flashing
disconnect printer, uninstall drivers, reinstall drivers & connect printer for set up new printer. let me know what happens.
Oct 28, 2007 | Epson Stylus C66 Inkjet Printer
Red light flashing
Oct 27, 2007 | OKI B4250 Led Printer
Epson Stylus 680 InkJet Color Printer Logo
111 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
