Question about Toshiba MW27H62 27" TV/DVD
DVD My Toshiba combo was about three months old when the DVD player went out. I purchased this unit in May 2006. In setting up controls it was fine except for the sound. I have another Toshiba I also purchased at the same time and it's sound is much better. But my biggest problem is loss of DVD player. I had called Toshiba and they were not useful at all. They recommended a tech who could not fine our house and when he called he said that he was a plummer? Anyway the dvd player when I first use it would show that the disk is being read. After about three months that no longer came up on screen. There was no way to open a menu or screen adjustment. What happens after disk is in unit after about two minuets a "Incorrect" disk appears. I have tried several disk and all result in same display. Is there a independent power supply to the reader of this player? Could a fuse be the problem? I read manual and pulling the plug had no effect on player. Any suggestions welcome.
    Guru:
  • 1,894 Answers
If you have a bad lens i would suggest you to use a lens cleaner disk for solving this problem.
if that does not help please let me know
Posted on Sep 10, 2008
  • dewan nafees ahmed Sep 10, 2008
    but if that does not help you will have to either send the unit for repair.
    if the repair estimate is costly its better to go for a new one.
  • Toshiba Master
  • 19,396 Answers
Try using a DVD lens cleaner
  • Ginko
    Ginko Sep 10, 2008
    Looks like the unit has more than one problem.
    Try first using a DVD lens cleaner, like the ones you can buy from here.
    This can correct the Incorrect disk problem, if it does not , regarding this problem, the TV must be taken apart and lens pickup must be cleaned with isopropyl alcohol and cotton.
    when is faulty the DVD power unit, you cannot even put inside or eject disks, it is not the power supply, it is the lens or the firmware.
    Regarding the sound, there may be many reasons why sound is bad (wiring, short, broken speaker, bad component on audio pcb etc.).
    Let me know your location if you want to find a repair service in your area.
What is the code for a Panasonic tv/dvd/vhs combo.....
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
www.eliztech.com/remotes/ge-new-3digit-combo-codes.php
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
https://www.att.com/support_media/images/.../set-up-code-list.pdf
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC - Farmerstel.com
Jan 01, 2016 | Panasonic Televison & Video
Three month old Toshiba 19"
call here for tech support
  • Televisions & other consumer electronics: (800) 631-3811 (toll-free)
May 05, 2011 | Toshiba 19CV100U 19 in HDTV LCD TVDVD...
My toshiba sdk990ku dvd player stopping playing the audio. Have connected via HDMI to LCD HD tv and worked for months! One day audio stopped, but picture is fine. Tried different HDMI cables, dvds with no...
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Nov 18, 2010 | Toshiba SDK990 Player
I have a toshiba D-VR610KU combo. Cannot get the
ACCORDING TO THE TECH AT TOSHIBA: THE UNIT MUST BE CONNECTED TO THE TV BY AN HDMI CABLE FOR THE DVD PART & (ON THE BACK-RIGHT HAND SIDE OF THE COMBO) YOU NEED TO CONNECT A SET OF THE RED/WHITE/YELLOW CABLES FROM (VIDEO) "OUT" OF THE COMBO & "IN" TO THE RED/WHITE/YELLOW TV(AV-1) PORTS FOR THE VCR PART TO WORK.
Oct 15, 2009 | Toshiba D-VR600
Jvc dr-mv78
The laserunits in some JVC sets are verry bad,for some sets there are updated units available incl software.
Aug 27, 2009 | JVC DR-MV7 DVD Recorder/VCR
Wont read divx on cds
I have had this same problem on my Toshiba. I went through the Control Panel and their were settings for the dvd player it used. You can change settings and they sometimes change automatically.
May 22, 2008 | Toshiba SD-K760 DVD Player
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Apr 07, 2007 | Zenith XBV443 DVD Player/VCR
Universal remote codes
NOT A SOLUTION, however my remote stopped working a couple months ago. I subsequently tried several universal remotes - none of these worked. An educated guess might be that the problem is NOT with the remote control unit, but rather something inside the set itself. This might also explain why the MW24FM1 you bought "didn't come with a remote".
Oct 23, 2006 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Toshiba MW27H62 27" TV/DVD Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
