Question about HP Compaq Evo Notebook N600c
Possible hard drive problem
After running a diagnostic on the hard drive it gives me a reading error message. This is a hitachi DK23DA-30F hard drive.
I can not do anything after windows has started (XP professional), the arrow is moving but can't click on anything. Hard drive sounds like a "broken record". Any ideas? Thank you.
    Guru:
  • 859 Answers
To quickly answer your questions and point out the actual limits and behavior based upon your statement.
A hard drive that exhibits a sound similar to a broken record normally indicates a damaged mechanical mechanism of the hard drive.
Having just said that, you shouldn't be able to boot up into a Desktop due to redundancy checks during the boot process. These checks examine the integrity of the data and the hard drive.
Once you acquire a Desktop have you tried to use your keyboard and not the mouse to access programs? And, do you notice that your normal programs and their icons load in the location occupied by your system clock?
What I would ask you to do to verify your hard drive's integrity is this:
Boot up your computer and after the beep start taping the F8 key. Shortly, you should have on display a Safe Mode Menu. Choose to enter Safe Mode and hit enter. When the desktop appears there is a pop up displayed to have you acknowledge you are in Safe Mode, hit enter or if your mouse is now working click OK.
Press these two keys at the same time exactly, Windows key + e key, When the Explore Window is on display you will see your c: drive listed, right click this and choose Properties. On the subsequent display choose the Tools Tab, now select ScanDisk and let this program run. Write down and Report back any significant errors encountered.
Thanks,
Worldvet
Please use the comment box below to talk back and I'll return to you soon thereafter.
Posted on Sep 10, 2008
  • 3 Answers
Sounds like you may have a crashed head. you can go here to listen to other drive failures to see if your drive sounds like one of these:
http://www.cybertechhelp.com/forums/showthread.php?t=120507
I would suggest however, turning off and not using your drive as much as possible. You may need to take your drive to a professional repair shop if the data on the drive is worth retrieving. There are a few companies that will recover data even from hard drives with failed hardware. They simply take your drive apart and retrieve it directly from the platters. http://www.salvagedata.com/
You might check to see if your drive is still covered under warranty for replacement.
When i boot my system it display a message unable to read hard disk drive then when run diagnostic test it givee me an error message-BIOHD-8
It pretty much means that your hard drive is going/has gone bad. Get a new hard drive and some software Acronis or Partition Magic for example to make a copy of that hard drive and perhaps you'll be able to save all of you data.
Sep 06, 2011 | Computers & Internet
I want to format my Hitachi disk drive( DK 23DA-30), But the system says- The disk is Write protected. How do I go about it? Kindly Help
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
-click start right click on my computer select open
-Right click the icon of your Flash Drive (It should be F:/ or something)
-Click Properties in the menu that comes up
-Click the Sharing tab
-Click permissions
-And finally, click Allow next to Full Control.
hope this helps you
Aug 26, 2011 | Hitachi (DK23DA-30F) 30 GB Hard Drive
A disk read error
Disk read error is an error you will get when the hard drive has problems. I would take it into a reputable show for repair. Often, a hard drive will fail and give you this message. It's possible the issue is virus related too, but when you get those types of messages; it's important to have a professional look at it.
Dec 30, 2010 | Gateway Computers & Internet
The laptop say's failed disk read, on start up. I did a system check and got this error reading. I am unable to start the laptop, just get the failed message. Would much appreciate a reply with a...
NTFS Read/Write Bootdisk And Bootable CDs
http://www.bootdisk.com/popfiles.htm
I bought this iso file from here. He charges $4 which is a bargain for this tool. Download the ISO on a working PC with a cd burner and create the boot disk. Boot the problem PC from the CD rom and run chkdsk from the black dos screen.
If this does not fix the problem then open the access door to the hard drive on the bottom of the laptop and find the make and model of the hard drive. Go to the hard drive manufactures web site and download a bootable ISO with the diagnostic utilities for the hard drive. This will tell you if it is fixable. Are you still under warranty? The laptop maker's web site may have a diagnostic tool you can download as well. This will give you a code which the manufacturer's help desk will need to authorize a replacement Hard drive. Other wise find a replacement drive from ebay or other suppler.
Sep 27, 2010 | Computers & Internet
How do i unluck my hitachi hard drive model dk23da-30f my sister forgot the password and dell can not help
http://www.youtube.com/watch?v=u37F2Y-dpkg this may help but needs to be viewed from another machine
Jan 18, 2010 | Office Equipment & Supplies
Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Most hard drives I've come across have tiny little letters on the PCB next to the jumpers that say MA SL CS which are for master, slave, and cable select. If that doesn't work, go to Hitachi's website and search their support section. There is a diagram of the jumpers for that drive out there somewhere. Good luck!
Nov 07, 2009 | Hitachi (DK23DA-20F) 20 GB Hard Drive
System boot problem
This is possibly a bad hard drive. If you know the manufacturer of your hard drive you can download diagnostic tools from their site, burn to cd and run diagnostics to check the drive for errors or failure.
Apr 11, 2009 | ASUS A8N-SLI Premium Motherboard
I switched out my hard drive from my old laptop to my new the both are Dells. My old is a T21 the new is a T23. Is this possible....
Providing that OS you are using contains the drivers necessary for this swap, and the drives use the same connection technology, yes this is possible.
To better answer your question, you can not harm anything attempting to boot from a drive which came from another computer, providing you make no modifications to both software and/or hardware for the connection.
It is common place for a device attempting to boot from a "foreign" Windows install/drive to Blue-screen or "Crash." You may attempt to install the drivers necessary utilizing Safe-Mode.
To enter Safe-Mode continuously hit the "F8" key on your keyboard during power-on.
If the device fails to boot to Safe-Mode, than your only option is to transfer any data necessary from one drive to another medium, or utilize both drives at once with an external device designed for your drive.
Let us know if you need any further assistance.
Thank you for choosing FixYa!
Jun 03, 2008 | Hitachi (DK23DA-30F) 30 GB Hard Drive
HP Compaq Evo Notebook N600c Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
