Question about Video Game Consoles & Games
Ps3 won't play ps3 games - Video Game Consoles & Games
  • jefcaswell Sep 14, 2008
    my playstation 3 will not boot up my games or blu ray discs please help
Hi Angieseveryt, I purchased my 60 Gig PS3 around 18 mths ago and after only 6 weeks of use it did exactly what yours seems to have done, it made a funny noise and the game dropped out and every time I put a game or movie in it just wouldn't recognise it was in there. I contacted Playstation support centre and they organised for me to send it to them to be replaced by a refurbished unit. I wasn't happy about having it replaced by a second hand modified unit, but they do not repair them here in Australia (or not at the time anyway). The PS3 was still under its 12mth warranty. I don't know how old yours is or how much it would cost if out of its warranty period but I would contact the Playstation support centre and push them because I'm not the only one to have the problem I believe it was a factory fault and their are many cases of this happening. I haven't had a problem with the new unit and the whole process of replacement was very quick and easy. I hope this was of some help. Let me know how you go. Chappo007
Posted on Oct 05, 2008
Discs won t spin
If your discs wont spin, I would contact sony if your PS3 is still under warranty. If not than buy a new PS3 or start buying your games digitally to play them with no disc.
Mar 09, 2014 | Sony Playstation 3 (PS3) Console
I live in South Africa and bought a PS3 Baseball game. It works in my PS2 but not in the PS3, because of the zone code. What is the correct zone code
I assume you bought a PS2 game that works on your PS2 system but not on your PS3 system since a PS3 game will never work on a PS2.
Since not all PS3 systems can play PS2 games, you need to first check the model number of your PS3 system. If you look at the back of your PS3, there should be a serial number somewhere that starts with "CECH", followed by one more letter and a couple numbers (e.g. "CECHC02"). Unless the model number starts with "CECHA", "CECHB", "CECHC", or "CECHE", you won't be able to play PS2 games on your PS3.
If your PS3 can play PS2 games, then you need to make sure that the region of the PS2 game matches the region of your PS3. The region of the PS2 game can be found in the upper-right corner of the front of the box the game came in. The four regions are: "NTSC U/C", "NTSC J", "NTSC C", and "PAL".
Once you know the model number of the PS3 and the region of the PS2 game, you can tell if the PS2 game should work on the PS3. Use the following chart to determine if your game and system are compatible:
Last two digits of your PS3 model number: Playable PS2 game region
00: NTSC J
01: NTSC U/C
02: PAL
03: PAL
04: PAL
05: NTSC J
06: NTSC J
07: NTSC J
08: PAL
09: NTSC C
11: NTSC U/C
12: NTSC J
Apr 29, 2012 | Sony Playstation 3 (PS3) Console
When using a hd cable for games no sound except a horrible wail?
Maybe the blu-ray/game part of your drive is failing, which won't read the sound properly. I had a drive that wouldn't read any audio, but did play the video.
Nov 30, 2011 | Sony Playstation 3 (PS3) Console
When playing Red Dead Redemption the game freezes
If a game freezes, then the problem is usually due to the PS3 overheating. The PS3 needs good airflow through the vents so make sure that you don't put it in a corner or in a place where the hot air won't linger around for long like near a window. Also, don't play for too long; give your PS3 a break every once in a while (1 minute breaks don't count) :)
May 30, 2011 | Sony Playstation 3 (PS3) Console
My new homefront ps3 will play on my friends playstation but will not play on mine help
If it won't play online what you'll need to do is set a static ip in your router for your ps3 and then open ports TCP Ports: 80, 443, 5223, and 10070 - 10080
UDP Ports: 3478, 3479, 3658, and 10070
(you'll need to contact your router about that)
If it won't play AT ALL follow these steps ( http://us.playstation.com/support/answer/index.htm?a_id=1488 ) to get into safe mode and select option 3.
If NONE of your PS3 games work and NONE of your blu rays work, your blu ray drive is fried and you'll need to get it fixed. You can go to: us.playstation.com/getservice to get it fixed.
Mar 21, 2011 | THQ Homefront PlayStation 3 for...
How do you set up playstation 3 to play playstation 2 games
One Surefire WayThe only way how to play PS2 games on PS3 is to have the correct version of the console. Either your Playstation 3 can play PS and PS2 games or it can’t, and there’s not much to do about it. Most of the PS3 models simply cannot play older titles as they lack the necessary hardware and firmware. However, a few models do have backwards compatibility. The 20 Gb, 60 Gb, and original 80 Gb models all have backwards compatibility, either through hardware or software emulation. The other models lack backwards compatibility, so even knowing how to play PS2 games on PS3 won’t help you out much here.
However, if you do have the correct console model, then there isn’t much to know for learning how to play PS2 games on PS3. Simply insert the game CD or DVD (many original Playstation games are also supported thankfully), and the game will start up. Sometimes, it will tell you that you can’t play the game, but simply hook your PS3 up via wireless or ethernet connection and update the firmware (which also provides improved compatibility with newer versions of Blu-ray discs). Often, this will fix the problems, but not all PS and PS2 games are supported (although most are).
There you have it. Learning how to play PS2 games on PS3 is easy, but if you just randomly picked a Playstation 3 model out at your local retailer, you might have a model lacking in backwards compatibility. One reason they didn’t include such compatibility with all models is an issue of cost, as it saved Sony some money to not include such a feature on all of the models. When they first started selling PS3s for $400, they were losing several hundred dollars (although they are at least breaking even now). Unfortunately, both the new 80 Gb and 160 Gb PS3 models are lacking in such compatibility, so you’ll need to find older models to support your older games.
Please rate my solutions! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
PS3 WON'T PLAY BLU-RAY DISCS
The problem is all in the settings. You probably have a 1080i television that cannot display in 1080p. To fix this go to the main menu and go to:
Settings:
Video Settings
Then Blu Ray Disc and make it turn the Display BD in 1080p 24hz or whatever. Once you do that, start the Blu Ray Disc again, and you should be able to watch it. This all happened because your tv doesn't display 1080p.
Hope this helps!
Jan 19, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
53 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
