I have a rca r52wm24 hd monitor the color is bad theres 4 of everything cannot access the convergance on menu ,watched tv repair person one time and he pressed some buttons together to get into a grid and adjusted it manually what buttons do you push
  • downsiii Jan 23, 2009
    I have green red and blue across the top and everything is bowed and doubled...how I fix it?
  • Anonymous Apr 19, 2009
    Problem Solver:
Shut off tv, wait 30 seconds, then at the same time press the channel down and the volume down buttons and wait for power light to come on and then release.
Posted on Dec 14, 2008
My 52 inch RCA projection tv has a blue line around everything white
The convergence needs correction. If its not able to be cleared up by running the auto convergence feature in the setu menu then you will need to repair the convergence. You can get free technical assistance and parts foor your RCA at www.tvrepairworld.com they are RCA experts with that chassis
Feb 10, 2013 | RCA R52WM24 52" HDTV Projection Television
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
50 inch rear projection hd ready model r52wm24 colors have separated and picture is bowed toward the middle top & bottom
sounds like the auto convergence option has disappeared from the set up menu. Press menu and scroll to setup and then enter setup menu and see if the auto convergence is still listed there or has it disappeared?
Jul 30, 2011 | RCA Televison & Video
Color distortion
You will need to install the RCA repair kit called ITC222 & ITC222A convergence option missing repair kit. Its available from www.tvrepairworld.com and it contains the parts and the CD with instructions.
Jul 14, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA TV MODEL R52WM24
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 28, 2009 | RCA R52WM24 52" HDTV Projection Television
I know that I need a convergence power supply board.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 27, 2009 | RCA R52WM24 52" HDTV Projection Television
3 color lines at top of screen no picture
If you do not see convergence in menu when you go to setup then you have a open fuse FL231 Next to flyback transfomer on right side there is 3 in a roll small brown rectanigler looking caps they are fuses the one in the middle is bad replace it .
Feb 11, 2009 | RCA R52WM24 52" HDTV Projection Television
Can't access to adjust convergence on my rca R52WM24 tv.
not sure if this will work press mute 183 on remote control
Jan 10, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Do we need a new TV?
I dont think this problem can be fixed without solder work or part replacement of convergence section. Its no just matter of fuse. You should get repair facility from concern service center because TV has dangrous voltages inside and qualified person knows how to deal with TV.
Jul 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
