Question about HP OmniBook XE3 Notebook
Screen problem....PLEASE HELP ME!!!
I bought a new inverter for my omnibook which worked fine but now the little black cable that goes from the inverter to the motherboard is bad. Can someone please tell me what the name of that small cable is and give me a part number for it. Thanx
How to fix screen problem on my laptop
Posted on Mar 28, 2009
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Turn on laptop, loads fine, screen comes up, then screen goes black. computer is still running and you can see it if you put a flashlight on, but screen remains black.
Try to adjust the back-light on the screen by pressing the FN and UP arrow to increase the light.
If that does not work then it means that your back-light on the screen has either failed completely of works for a couple of minutes and then it goes off. You need to have your screen replaced with a new one.
Sorry for the bad news.
Sep 21, 2010 | Dell Latitude D600 Notebook
Brightness is off - screen is black - I can force it to work by toggling the stand-by button on my Acer Aspire 5100 - is it the driver or will I need to get an inverter? Screen went black but the computer...
i cant sugest anything but what i can say is that i think you will have to get a new screen that is my oppinion.
sorry for the inconveience.
please rate for my help to you.
thank you.
Apr 22, 2009 | Acer AL1917W LCD Monitor
Screen goes black
Could be a loose cable connection the cable that runs between the LCD and the laptop my come loose from time to time and the screen will go black you have to be carful with this because you may be shorting out the inverter and eventuly you will have no picture it should be and eas fix if the cable is loose Go to the manue or service guide and find out how to open the Lcd cover behind the Lcd sceen there should be a connector make sure it is properly connected
Mar 24, 2009 | Compaq Computers & Internet
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
I have a Poloroid LCD flat screen, 42", bought it at Walmart 13 months ago. around 2 months ago the picture stopped staying, the screen goes to black. We have sound but no picture. we were re-booting and...
Hi pdooley1, I will be happy to help, We need to check the backlight, the easiest way to do this is,
  1. Turn tv on to a point you have sound.
  2. Take a flashlight or a lamp with a bare bulb and shine it on the screen.
  3. Look very closely at the screen and see if you see a dark video image.
If you can see an image you have a bad backlight inverter. let me know what you find and I can assist with replacement. Please rate this solution. lone99star
Jan 13, 2009 | Televison & Video
My monitor works for a little while, then goes black.
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
OR
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
ebaysbammbammfran
Oct 11, 2008 | E-Machines eMachines Monitor E15T4
Screen gone black
Sounds like the screen inverter may be going out. The only real way to check it is replace it or take it to a shop and have them test it.
Jul 04, 2008 | Dell Inspiron 6000 Notebook
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
HP OmniBook XE3 Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
