Question about Sanyo PLC XP41 Multimedia Projector
Projector randomly shuts off
Hello, After 2 years of use, one of our 2 projectors has started randomly shutting off. It first happened after about 3 hours of continuous use, and now it happens after about 30 minutes. It's done this about 8 times now over the last 2 months, but is now happening nearly every time we use it. None of the warning lights come on, and it will restart after about 2-3 minutes. There's nothing in the book that addresses this issue. These projectors are mounted on a pole, upside down, about 30 feet off the ground in our church sanctuary. Does anyone have any ideas? Thanks very much!
  • Earl Bingham Apr 07, 2006
    Thanks! That's about the only thing I could come up with as well, but it is 30 feet up and not a simple matter! I wanted to make sure I didn't need to take any other tools up there too! Thanks again for the quick reply!
    Champion:
  • 277 Answers
Hi CLEAN IT!! all these things leads to 1 conclusion: the device is packed with tons of dust it has a safty powerdown on heatup http://www.fixya.com/user-guide/p196016,m4858,gm38/Sanyo-PLC-XP41-Multimedia-Projector.aspx good luck
Posted on Apr 06, 2006
Epson Powerlite 830p lamp light comes on and turns off projector with new bulb.
Clean the fans and filters. Check the lamp door switch is making contact.
Jan 27, 2018 | Epson PowerLite 830p Multimedia Projector
Cinego is randomly shutting down
if it is overheating, blow out the projector with canned air. excessive dust keeps in the heat that the projector is trying to expell. also, make sure all of the fans are working properly. if it's cleaned out and the fans are running, you may have a main board issue.
Nov 29, 2009 | Radio Shack Cinego D-1000 Multimedia...
Optoma DV10 randomly shuts off completly during a
check the power timer settings and put it to disable setting, Or avoid anything that cover the exhaust, fan if the problem occur get assist to the technician.
Oct 22, 2009 | Optoma MovieTime DV10 Multimedia Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
HP vp6320 projector ten seconds it shuts off
I had the same problem, the first couple of replacement bulbs i ordered worked fine but the last 3 i got, 2 of them have been faulty, i just sent them back and they replaced them. If its too late to send the bulb back you can go to the settings on projector, select lampsaver setting, its probably set at off, turn it on. Your bulb will be a little dimmer in this setting but shoud let the projector run ok.
Dec 01, 2008 | HP vp6320 Multimedia Projector
Optoma projector
would need a model number to get this nailed down but it sound like you have a DLP projector, this might have a color wheel in it, sometimes when this fails you get flash of colors as the color wheel slows down then the unit sences that the color wheel has stoped and shuts down the unit
Mar 07, 2008 | Optoma Multimedia Projector
Optoma H56 - turns off just after start up.
It's not a short, the blub is near the end of it's life ~ the optoma is designed to detect when the blub is about to blow and shuts itself down. Turning the projector upside down or right side up usually only gives you a brief reprieve (some have reported a modest amount of extra time gained) on the blub ~ but in the end it's on it's way out and the projector will shut down again.
Oct 14, 2007 | Optoma H56 Multimedia Projector
Shuts off
projector turns off after 30 seconds problem solution
Sep 16, 2007 | Sanyo PLC XU35 Multimedia Projector
Optoma hd72 bulb turning off
This is NOT a bulb problem unless your "lamp" LED is lit, which you say it is not. Many people have reported this problem with the Optoma 72. You can send it in for warranty service (it has a 2-year warranty) to get the lamp controller chip replaced, but the problem may recur. Optoma does not appear to have a permanent solution to this problem. My projector has broken exactly like yours TWICE in a year. I haven't even needed to replace the original bulb yet. :(
Nov 05, 2006 | Optoma HD72 Multimedia Projector
Sanyo PLC XP41 Multimedia Projector Logo
623 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Rod Donovan
Rod Donovan
Level 1 Expert
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
