My Zenith SEq Stereo TV was purchased in 1993. The picture is only 4-5 inches in height and black at the top & bottom. Is this fixable?
  • Anonymous Jan 14, 2009
    video srceen blue
  • 4,234 Answers
Yes it is fixable. There are one or more bad caps in the vertical circuit. If you would post the model number listed o the back of the set, I should be able to give you more details.
Thanks,
Dan
Posted on Sep 10, 2008
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
I have a 26inch Console Zenith Color TV, when I turn it on, I get a full pidture and sound but after 30 seconds, about 6-10 inches of the bottom screen goes black--but the rest is ok???
Get the remote control and press the MENU key repeatedly until you see the Video menu at the bottom of the list of options you will see EZ Picture.
Use the up/down arrow keys to select EZ Picture and use the left/right arrow keys to select your preference. Set the preference to Preset not custom.
Press Enter, Quit or Menu to exit. See if resetting the TV's Picture settings resolves the problem.
If you have a bar at the top of the screen as well then it could be in letterbox viewing mode. Again just go into the Video menu and turn it off.
Please let me know how you get on.
Good luck.
Jan 14, 2010 | Zenith C27A24T 27" TV
Zenith Z25X31D Verticle Adjustment
open up the set and on the board there are 2 small potentiometers mounted on the board called Vert-Linerity and Vert Height, I believe the adjustment of the Linerity control will fix your issue
Sep 17, 2009 | Zenith Z25X31D TV
Zenith seq stereo tv, stuck in aux mode
large black box in the center of tv screen
Jan 15, 2009 | Zenith Televison & Video
TV picture size (height) adjustment
TV model # PCJ 612 R SAMSONG SERIAL # 39Z 300 125 W
Dec 06, 2008 | Televison & Video
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Picture Shortens, Converges, eventually the set shuts off - $50 for Correct Solution
Open the TV amd turn it on in a position you can see the picture, possibly through a mirror. Now gently tap all of the metal heat sinks on the circuit board until you find the one that is sensitive it will have a small chip mounted vertically on it, with probably like 7-10 pins. The number on the chip will most likely be an "LA****" number. Now turn the circuit board (UNPLUG FIRST) over and resolder the pins. This is your problem 99% of the time. Be very careful there is High Voltage inside this TV.
Apr 26, 2007 | Zenith IQB36B42W TV
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
