Question about Garden
UV light used to kill bugs; does not come on when plugged in with new bulbs.
I ordered
  • nbeach5 Sep 11, 2008
    The product is a STINGER HIGH PERFORMANCE UV801. It uses 2 florescent light bulbs to kill bugs in an electrical double wire grid. Where one bulb plugs in I can see a flickering glow the other one has a constant glow. Is this eniugh info? Thanks.
    Brigadier General:
  • 3,614 Answers
Kindly provide me a complete info regarding on your problem please...
thank you
Posted on Sep 10, 2008
  • micromaster
    micromaster Sep 11, 2008
    first check the contact of the bulb into the connector / socket... 2nd try to interchange each bulb by testing the other light into the one socket which the light bulb has no problem..
    let me know
  • 19,396 Answers
Provide more details on your problem please, we cannot read the title in full.
Thanks
  • Ginko
    Ginko Sep 10, 2008
    Check the UV light power cord, if the power cord is ok there my be a lose contact inside the UV light.
    Guru:
  • 1,894 Answers
What you ordered and when??
what is your problem sir?
can you explain me your problem?
  • dewan nafees ahmed Sep 10, 2008
    if you could could give us more details about your problem it would help us to assist you better.
    also mention us from whom you ordered the product and when you ordered it.
    what is the exact fault? that will help us to give you a exact solution for your problem
    thank you
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
Tip
Duct Cleaning Can Be a Messy Job Or it Can Be Made Very Simple
There are many companies that advertise <b>air duct cleaning</b> as a way to make the air in your home cleaner and healthier. While that is a good thing, there is a better way to improve the air quality of your home. With the installation of a <b>UV light based air cleaner</b> your can keep the ducts of your home clean and free of the many bad things that like to grow in your<b> air ducts.</b><br /> Many people today are becoming concerned about the air ducts in their home. These are the passages that the air flows through to heat or cool their homes. They can become a breeding ground for numerous <b>molds, bacteria, and virus.</b> With the addition of a very simple appliance you can eliminate much of the danger that could come from your ductwork.<br /> <b>Ultraviolet Light</b> has been used for years to help to kill bad bacteria and <b>sanitize equipment</b>. <b>Water treatment facilities</b> use UV to treat the water before it is released into streams. In homes with wells that are contaminated, water can be treated by passing by a UV light. This type of light is very effective at killing micro-organisms quickly and efficiently. Some of these systems are even effective at getting rid of hard to kill things such as <b>SARS </b>and the <b>Swine Flu virus</b>.<br /> Now it is very easy to install an <b>Ultraviolet Light in your air ducts</b> to kill the many bad bugs that like to live in there. It is a simple as cutting a hole in your ductwork, mounting the unit to the side of the duct and plugging it in to an ordinary outlet.<br /> While a <b>physical cleaning or your air ducts may be a good idea</b> it can be very expensive, dirty, and time consuming. Also to do this means that the ducts must be cut into in many places and sealing them up again permanently is a problem. With this type of unit your ducts will self clean over time. I have seen many ducts that slowly clean them selves after the installation of a UV unit. It will not dissolve big hard items in your duct but it does tend to dissolve small dust particles and make your duct look cleaner.<br /> The main result of installing a UV unit in your <b>HVAC system</b> is that you will be breathing air that is free of the bad stuff that can cause health problems. Even if you choose to have your duct vacuumed and cleaned also consider the installation of a UV system to keep your ducts clean and sanitized.<br /> <b>Clean sanitary ductwork will give you and your family the healthiest, freshest air to breath possible</b>.
on Feb 19, 2011 | Heating & Cooling
How do i remove the uv bulb
Place your finger in the door recess on the right-hand side of the sanitizer and pull open the door.
Remove the drip tray.
Remove the protective screen by gently lifting it up and pulling it forward.
To remove the UV light bulb, pull it out of the lamp holder.
Install the UV light bulb by snapping it into the lamp holder.
Align the pegs on the protective screen with the slots in the reflective surface of the sanitizer on either side of the UV light bulb.
Insert and gently push down the screen to secure it in the sanitizer.
Reattach the drip tray.
Dec 13, 2014 | Air Purifiers
Why does my 86 2.9 l. ranger kill spark plugs
your truck is running too rich with fuel if you have a carburator have it check
Sep 18, 2012 | Cars & Trucks
Can you clean the clear tube that seperates the UV bulb from the water in a Tetra Green 2 UV?
A test tube brush or a small bottle brush will fit and not damage anything. Alternatively as long as it is not used for saltwater soak in a bucket of 5 gallons water and a 1/2 cup of bleach will kill and separate any algae. Just rinse thoroughly to flush out any leftovers and to clear the unit.
Apr 10, 2011 | Tetra Green Free Uv - 2 Clarifier - 18...
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
The screen is turning blue. what is the problem? I just had the bulb replaced a couple of months ago.
Your Optical Block is failing. It needs to be replaced in order to fix this. The details of the mater, if you are interest: The Mercury vapor lamp used in the TV emits UV light. UV light has a short wave length and is therefore positioned on the violet side of the spectrum. Blue, being the closest of the 3 colors (red, green, blue) in wave length, deteriorates faster due to UV damage. UV light damages most things, it is unavoidable. If the UV light was trimmed out by filtration, your picture would be far to dark to view. So, it must remain at some level... even if in time it will destroy the LCD panels (which it does... in every rear projection LCD TV which uses a Mercury Vapor lamp.) As for the fresh lamp... this is common. Your lamp is back up to full UV power and your picture is bright. You can now see the damage progressing more quickly. I hope this was helpful or at least explained the "how and why" for you, best wishes.
Apr 22, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Fresh Air Display on and NO POWER
possibly a bad control finger control board. had a problem just like that and that repaired it.
Mar 27, 2010 | Ecoquest Fresh Air Living Air Purifier
Replaced RCI Cell 2 times, light still doesn't come on
The U.V light is inside the RCI cell. If you replace the RCI, it has been ok. Please don't mind the screen display.
Oct 09, 2008 | Ecoquest Fresh Air Air Purifier
Garden Logo
165 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
