Question about Philips HTS3450 System
Can I use a higher voltage capacitor
I want to replace a 470uf 25v capacitor with a 35v one due to availability. This is for a LCD monitor. Are they compatable?
Thank you
  • 10,594 Answers
Yes, its safe, if working volt is 35 and capacity is 470uf, thats fine.
Posted on Sep 10, 2008
Refrigerator clicking
There are 4 capacitors that need to be replaced to solve this issue with WKKT Model No: 0158-06-03 These caps are listed below. C106 470uf 25v recommended (470uf 35v) C29 470uf 25v " " C6 10uf 25v C100 47uf 25v
Feb 02, 2013 | GE Refrigerators
Samsung Monitor Backlight/Power Issue
hi, these mosfets are obsolete now, do you know a good equivalent for them?
Thanks
Aug 16, 2012 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor comes on then goes black
I've got a couple of these monitors that have the same problem. All the caps in the P/S except the large inverter filter (110uf/400v) are bulged. I;ve ordered all the caps - INCLUDING the one that doesn't look bad since all have been subjected to the same high heat (or are bad caps in the first place {Non standard?} so am attempting to prevent a recurring problem. Since all of them cost around $6 TOTAL (plus s/h) there's absolutely NO reason not to replace all of them. The ones in my monitors are: 1-22uf/50v, 1-100uf/400v, 1-470uf/10v,2-1000uf/10v and 3- 470uf/25v. I opted for the slightly higher voltages available when I ordered since that also helps and there's plenty of room. the 10v caps will be replaced by 16v ones, the 25v by 35v while the 50v & 400v will be the same voltage. Hope this helps somebody. Good luck and solder quick to keep the heat down.
Apr 18, 2010 | Princeton Digital VL2018W Monitor
My Sceptre X32B sill not power on
Other sites show that power up problems are due to the aluminum electrolytic capacitors on the power supply board being defective. Replacing the four 470uf 25v capacitors (470 micro farad, 25 volt) on the board usually fixes the problem. Sometimes also the two 1200uf 25v capacitors could be the culprit. I suggest changing them all. The price is about $7 for the parts online at Mouser electronics plus $7 shipping. I just fixed mine. I bought two 1200uf 35v capacitors, Mouser part number: 647-UPJ1V122MHD6 and four 470uf 25v capacitors Mouser part number: 661-EKY250ELL471MH2 These are slightly larger than the originals but still fit and they were in stock. You will then have to open the unit (relatively easy) remove the power supply board by removing four screws and disconnecting the connectors (Make a note of wire colors and where the connectors came from before removing). Then you will need to remove the old parts by desoldering them and then solder in the new parts (somewhat easy if you have soldered before)
Nov 28, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Stuck in standby
There is a "reliability kit" sold for these which consists of 8 electrolytic capacitors for the power supply that may cure the problem. Other times more extensive damage to the switch mode power supply needs additional parts You can try replacing the 4 470Uf/ 35v and the 4 470Uf/ 25v caps.
Monitor Mike
Apr 16, 2009 | Televison & Video
Proview monitor fix
I did it just because the higher voltage caps would give a lower heat dissipation thus leading to a longer life this time around.
Oct 17, 2008 | Proview PL926WBi 19" LCD Monitor
6800uf/16v Capacitor?
You can use a higher voltage capacitors without problems its the value of uf that should remain the same. But sometimes you can use a higher uf like a 330uf can be replaced with 470uf but never go lower than the original value on uf and voltage. But you can safely use 6800uf 25v or 35v.
Jul 07, 2008 | RCA RT2500 System
Can changing 3 capacitors on motherboard solve my problem?
We had a power surge and my VL2018W LCD monitor stopped working... blank screen and flashing blue light.
I carefully opened up the back and found the power board (the one the AC plug goes into). There were about 5 electrolytic capacitors that were bulging (but not ruptured). There were 3 with the values listed by the original poster (470uF @ 25V) and 2 with 1000uF @ 10V.
I scrounged a couple of 2200uF@10V caps for the last two and bought 3 470uF @ 35V caps from Radio Shack (P/N 272-1030).
Luckily, the monitor came right back up and seems to be OK. It was out of warranty, so there wasn't a big risk.
Just increasing the working voltage won't do that much for you. If any caps are bad, just replacing them with the same value is good enough, but a higher working voltage won't hurt (usually means a bigger cap).
Good luck.
Rich
May 04, 2008 | Princeton Digital VL2018W Monitor
Monitor Powers off after a second or two.........
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
Replacing Capacitor on LCD Monitor
That is good advice. Always replace with same or higher voltage rating. Also make sure it is put in the right way around.
Sep 21, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Philips HTS3450 System Logo
109 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
