Question about Sharp Microwave Ovens
The piece of **** we own is pt# r-1500. In less than a year the lcd display shut down. Now the switch assembly has broken and we have been informed the entire control panel assembly is unavailable. Nice performance!
  • 100 Answers
Both parts are readily available - you can order them from Martin Microwave Inc.
(toll free 1-877-894-0035).
The lcd / control board / display is Sharp part # CPWBFB075MRU0 and it sells for $79.99
The button assembly is Sharp # JBTN-B122MRF0A and it sells for $13.99
You can also check with www.microwavedisplay.com for a rebuilt board
Posted on Sep 10, 2008
The part that holds the door switches inside the oven is broken; can the part be replaced
Yes this can be stuck using a instant glue if the broken pieces can be found. Usually this needs to hold the switch and lock in alignment.
So try this out , you can remove the front panel and get access to this assembly.
Jan 21, 2013 | Microwave Ovens
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
GE Spacesaver microwave always runs when the door is shut
I see this all the time. In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 10, 2010 | General Electric Microwave Oven
Microwave keeps shutting off
The magnetron is overheating, tripping the thermostat, which shuts off all power until it cools down.
This is usually caused by a blocked air vent, failed internal cooling fan, or failing magnetron.
If it's out of warranty, I'm sure you'll find it's uneconomical to repair, even if you could get parts for this brand.
Good luck.
Dec 26, 2009 | Oster Microwave Ovens
Sharp R-1750 shuts down.
The shutdown you're experiencing is separate from the control unit / display issue.
The shutdown is probably due to a a loose fuse holder, loose wiring, or a problem on the inverter board or the magnetron.
If the control unit doesn't receive the proper signals form the inverter, it will shut down the cooking process, but you say it acts like it's being unplugged - that makes me suspect a loose fuse or wiring.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person attempt to take readings on these inverters.
We actually have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
If you get the shutdown problem repaired, we'd be happy to repair your display problem for you.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 19, 2008 | Sharp R-1750 Microwave Oven
How can it come on-but not really?
This is usually a bad door switch or door switch mount.
If it's less than one year old, it's under warranty and you should contact Frigidaire to get it fixed free.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
We appreciate your thoughtful rating of our answer.
Nov 11, 2007 | Frigidaire FMV156DC Microwave Oven
LCD Display failing
This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to disassemble it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 08, 2007 | Sharp R-1505 Microwave Oven
LCD display missing part of numerals
Yes, we repair these displays for $32.50 with a one-year guarantee. Repair Clinic charges $169.35 for the display board assembly. Tritronics (our supplier) sells the assembly with display (part # DPWBFC167WRKZ) for $107.07. On the rare occasions when we actually replace that type of board for our customer (at our cost of only $73.33) we also perform our proprietary fixes on it. We do that so the new display does not also fail in a few months, or even right out of the box! That actually happens!
Oct 18, 2006 | Sharp R-530ES Microwave Oven
Microwave
I wiggled the ribbon cable between the control board and the intermediate circut board. The LCD came back for an instant. I am sure it is this ribbon cable. It looks like it is held on with adhesive. How can it be impossible to repair if people are offering to do it less than 40.00 dollars to fix it? Someone must be selling a replacement ribbon cable that will work.
Mar 20, 2006 | Sharp R-1501 Microwave Oven
Microwave Ovens Logo
168 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
