Gapping/overlapping of letters
We have the IBM correcting Selectric II and for some reason when the lock key is on there will be a large space between some of the letters, causing an overlap onto the next typed letter. Any ideas on what might be causing the problem and can I fix it? Thanks for your assistance! Teresa
  • 3,594 Answers
Its sounds like tou may need a rotate adjustment. Take it in for service.
Posted on Sep 13, 2008
How to unlock typewriter?
Remove cover and in the back there is the motor and belt, with machine off, try turning the belt. There is a tool that screws into the main cam shaft that allows you to turn the main cam shaft. most likely something is stuck. These IBM Selectric need oiling on a regular schedule.
Aug 15, 2017 | IBM Office Equipment & Supplies
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
The alignment of a couple of letters (i.e., "m") on by IBM Selectric II is askew. How can this be fixed?
It may be as simple as replacing the element (ball). Remove it and look for broken ao badley worn teeth on the lower edge of the ball.
Jul 31, 2013 | IBM Correcting Selectric II
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
Aug 31, 2009 | Office Equipment & Supplies
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
On the IBM selectric 2 - the keys are locked up -
Try the shift key, then try pressing each key on the key board one may be partially tripped.
May 07, 2009 | IBM Wheelwriter 30 Typewriter
Typewritter won't correct!
After you press the corr. key you must retype the wrong letter then type the correct letter.
May 15, 2008 | Office Equipment & Supplies
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
127 people viewed this question
