Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Timer Timmer dose not advance. I have replaced the timer and it still has the same problem.
  • 409 Answers
Check the pin connector between the touchpad & control board and ensure that it's seated correctly in the slot on the control board. if this does not solve the problem replace the control board.
Posted on Sep 13, 2008
Timer keeps going off
push in timmer knob turn till its at 12 o clock if it does not shut off then the timmer is bad can dissconnect timmer from the back ..turn off breaker or unplugg. dissconnect wires from timmer .. tape connectors real good .now no annoying buzz
Aug 22, 2010 | General Electric Stove/Oven/Range Chrome...
Ecoplus Digital 120v Timer Dual Outlet 24hr 7day Timer: my timer is not cutting on when i have it set to....
Make sure your timmer is set to "AUTO" mode and that your programed times/weekdays are good, resetting the timmer should solve your issue i've had it before, these timmers do this to me once and a while.
Make sure you dont have an "O" on the left of your time as this randomises off/on times by 2 to 32 mins. Press "HOUR" and "MINUTES" at the same time to toggle this option.
the timers manual can be found here:
Eco Plus Digital Timer
May 18, 2010 | Day-Timer Ecoplus Digital 120v Timer Dual...
Danby DT4229 Top Load washer. the washing mecahism
HI. If the timer dial dose not advance, this will indicate that the timer motor has failed. Generally, this will require you to have this damaged timer mechanism replaced, asap. Unfortunately, these mechanisms are not designed to be repaired. The entire device must be replaced, if possible.
Jan 19, 2010 | Danby DTT420 Top Load Washer
Coil is freezing, stops cooling, no water at despencer. turn timer knob manualy and it does shut off and back on again. defrost timer or heater?
depends on the brand, most likely the defrost thermostat.
heaters rarely go bad, timers usually will not advance causing the coil to frost over.
if you turn the timer to the "defrost" position and wait for 20 minutes. after a couple of minutes it should have the heater get hot and then frost should drip onto the heater and make a "hissing" or "sizzling" sound. if it does make these sound, then replace the timer.
Dec 31, 2009 | Refrigerators
Will not finish cycles, two hours later I will look and the tub is full of water or it may not finish spin cycle. Suspect the control timmer?
The timer mechanism is faulty. The timer is the mechanical computer of any washing machine. It simply works by connecting different circuits together for a predetermined time. If a particular cycle isn't working, the timer unit will need to be replaced. You can manually advance the timing unit by pulling out the knob in the middle of the unit, rotate the dial to the desired cycle then push the knob in- that will start that cycle. Good luck, Jim
Aug 28, 2009 | Washing Machines
Drier was working O.k . Timmer Stop working And so did the Heating. Does the Timmer control Temperature aswell.?
Yes, if the timer mech is damaged and, it will not rotate, this is cause the heating cycle to become inoperable. the time is responsible for initiating the heating command and the thermostat helps with the temp regulations. replacing the timer will restore the normal functions of your dryer.
Jun 18, 2009 | Whirlpool LER5636P Electric Dryer
Timer does not move in Auto/delecate
Im guessing there is another thermostat in the circuit to actuate the timer motor circuit. If you can find the timer motor wires check for voltage in the run (cycles yuor having trouble with) modes. Automaticadvance timmer mode is usually an open set of contacts and close when the element is heating too correct temperature allowing power to continue to the timmer motor. In the delicate cycle often it is the same thermostat on a differant set of contacts (but they could be on the same thermostat this type of thermostat has 3 termjinals usually 2 on 1 side and 1 on the other). that energize the timer motor.
The other thing that could be the problem is the timmer itself. There has to be a set of contacts inside the timmer that energize the timer motor in both cycles. these are or can work on some cycles but not others due to worn out parts in the timer. Check for voltages her that corrospond with your timer motor.
Hope this helps Please rate me accordingly and GOOD LUCK
Mar 08, 2009 | Amana ALG443RAW Gas Dryer
Timmer assembly
this a 115 volt single phase timer you can buy the timer at or jump the timer by jumping the red and brown wires but the timer will not work if you want the phone # of hobart tell fixYa to email me and i will leave the number they are located in jackson hieghts N.Y
Oct 30, 2008 | Hobart D300-6036 Mixer
Washing machine gone crazy
Does the timmer advance at all? Timmer motor. on timmer if timmer not advancing.
Mar 30, 2007 | Frigidaire GLWS1233A Top Load Washer
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
67 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
