Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2005 roadking wont start.
L left my ignition on and ran down the battery. I tried to jump start the bike. the motor turns, however there is no spark or hum from the fuel pump when i turn on the ignition. I checked all fuses and they are good. I also noticed that the system relay does not engage when ignition switch is on. Any help would be appriciated.
  • tecsmith Oct 30, 2008
    let the battery run down; tried to jump start with car (without car running). Gives one kick then clicks.
  • Carl Navarro
    Carl Navarro May 11, 2010
    I didn't know that phones had ignition switches :-)
  • 216 Answers
You didnt mention how you tried to jump it. If it was from a car battery, you could have fried a sensor. If the car you jumped it from was fired up while conneted to your bike, thats the problem right there
Posted on Sep 11, 2008
Motor blows fuse
there is a short in the system that is connected to that relay/fuse. Could also be melted wires if you tried to ever jump start it from a car, start position on a charger or jump start box. Jump starting a motorcycle should never be done. The gauge of wires on a motorcycle are much lighter than vehicles.
It is VERY rare but i have seen batteries that are reversed polarity. Check to make sure battery is 12v + when you test it. Not 12v -
Apr 03, 2014 | 2007 Suzuki Boulevard S40
Bad gas bike wont run?
Hi Anonymous, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
For a primary suspect please visit the website below:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Good luck
Feb 08, 2014 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Roadking 2008, wont start
I need to know a little history a bout the bike has it been sitting ?how old is the battery how old are the spark plugs ? is the engine light on in the speedo? can you here the fuel pump cycle on then shut off when you turn the ignition on ?
Sep 08, 2013 | Harley Davidson FLHRCI Road King Classic...
I have a 2003 DynaGlyde, Carbureted, security and a battery that holds charge. The bike sat for a year I went to pick it up got it home in the back of my truck threw my battery charger on it to 15 amps...
Man, that's the best description I've ever seen of a problem with a bike on this site. Regrettably, I don't have a clue as to what the problem is but I can tell you that I've read about the turn signal staying on in many instances. I'm an old school biker and mechanic and I don't have any experience with the computer controlled bikes or security systems. To me, it sounds like the security system has got the bike disabled for some reason. This seems to be the case mostly when the battery goes dead and then the owner recharges the battery or installs a new battery. The security disables the ignition system thinking someone is trying to steal the bike and it communicates with the owner or mechanic through the turn signal system. Have you read the owner's manual about the security system? The turn signal staying on constantly may be trying to tell you what the problem is. I really wish I could help more but that's all I've got.
Good Luck
Steve
Jun 01, 2011 | 2007 Harley Davidson FLHX Street Glide
I am having problems getting good spark could a battary cause this problem low voltage even though it turns over (94 yamaha fzr 600)
Yes occasionally a battery can put out enough cold crank amps to spin the starter and motor, but in doing so drags the voltage down so the electronic ignition wont fire.
a couple of warnings
If you check for spark make certain there is a plug in the lead and it is grounded to the engine, if not the voltage builds up in the coils until it can spark to something.
dont jump it of a bigger car battery, when the bike starts it can try to produce more amps than its supposed to to try and charge the car battery and stuff the reg.
Jun 19, 2010 | 1994 Yamaha FZR 600
No spark at spark plugs so wont fire new battery all connections and grounds seem good was sitting for 3 months and ran at that time someone had turned on key and ran down the bat. so replaced but now have...
Check the coils first, leaving the key on may have burnt out part of your ignition system.
Easiest way to check coils is to pull one lead off, plug a spark plug into it. Run a hot wire from the positive side of the battery to the coil ( Do Not Plug it in!!) . If you flash the wire on and off the power side of the coil it should make a spark jump across the sparkplug ( don't forget to earth the base of the plug.)
If the coils are ok, see if you can borrow a CDI unit to try in your bike ( it is good to have mates with the same brand of bike )
Don't forget to check all fuses first and make sure the "Kill Switch" on the handlebars is on.
Happy fault finding.
Mar 29, 2010 | 1986 Yamaha FJ 1100
My bike won't start
First make certain the fuel is fresh ,and drain any old fuel out of the carb ,small screw at the bottom of the float bowl.when dry turn fuel on ,if flow starts again no blockage .start bike now,if no fix, remove spark plug if it is dry the carb is blocked . touch plug to cylinder head and start be carefull not to shock yourself use pliers . If no bright blue spark check side stand cut out switch ,kill switch . if the battery has been left uncharged for more than 2-3 months replace as wont work well. to check for seizure remove plug and push bike in first gear you should hear and feel the engine turn.
Feb 14, 2010 | 2005 Yamaha WR 250 F
Wont start getting weak orange spark
Hi, Kinwin and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test, your battery may show 12.5 volts but has little or zero amps and must be replaced.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or CDI or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
No Fire solved Thanks Everyone
How to diagnose no spark situation on motorcycle
Honda SHADOW VT1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Mar 30, 2017 | 2002 Honda VT 1100 C2 Shadow Sabre
Bke wont start
Hi there, try this sometimes the stand switch can make the bike not work if has got rusted at the back.and check or replace the coil., then check if you are getting a spark from the plug by putting the spark plug on top of the head. The next thing is if the bike turns over but not fire up, you need to strip down carb and clean jets, also check petrol value under the tank If you have a book it will go through this step by step. good luck.
Feb 21, 2009 | 2005 Honda CBR 125 R
Bike cranks and wont start
Hi .... Sounds like regulator/rectifier is defective. Fully charge battery and try starting again, place multi-meter across battery and it should show 12.8-14 volts. If it doesn't replace reg/rec unit.
Jan 04, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Lands Phones Logo
160 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
