Sanyo DS31520 31" TV
Problem for Sanyo DS31520 31" TV
Tv has no picture
By poage on Apr 06, 2006
My sanyo 31" tv will not show a picture. When I turn it on I see nothing but static. When I turn it to video it works fine. So I'm able to watch dvds but not cable. I have checked the cable in two differnt rooms and it does the same thing. The other tv works fine on these cable outlets. If you have any information I would appreciate it. Thanks
Comments:
Apr 06, 2006
- I have no kids and tv was on then went to static. Picture was fine. It was working fine for about a week. Got tv from inlaws who said it was working fine. only items plugged in were audio video and cable. Thanks
Apr 07, 2006
- placed tv next to it and worked fine
Solution #1
posted on Apr 06, 2006
Somewhat Helpful)
techman
Rank: Guru  Sanyo Expert
Rating: 86%, 7653 votes
sounds like a antenna block problem or a tuner?? Now Im wondering if this set has mutiple antenna inputs?? if it does then the antenna input switch is on the wrong mode.
Comments:
Apr 06, 2006
- sounds like a bad tuner bud. sorry bUT just because the cables working in the other rooms dont assume that alls good with the cable as could be as simple as a bad spitter or connector.. place another set right next to the bad one and see if it works?? if it does then you know for sure.
Apr 07, 2006
- like I said then its most likly a bad tuner in the set. dosent this set have a video input?? as I got a set 4 years ago that had a bad tuner but had a great picture on it and I simply used a video input from a cable box and this set is still working good today!! Good Luck!
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
BowerR64
Rank: Wiz
Rating: 80%, 980 votes
Do you have kids? is the tv low enough they can push buttons?
Was this helpful?
Yes
No
Popular Solutions for Sanyo DS31520 31" TV
Questions and Unsolved Problems for Sanyo DS31520 31" TV
Do you recommend Sanyo DS31520 31" TV?
Answer
Answer
what is the serial number of the power supply of a Sanyo television
Answer
i have a sanyo tv but misplaced the manual for my remote need directions and codes to program one... (More)
Answer
blue screen with a padlock.no sound and picture.when you put it on it show a picture then it locks... (More)
Answer
reprograming sanyo remote control. I have the code
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
