Question about Brother LS-2125 Mechanical Sewing Machine
DISNEY BROTHER SE-270D COMPUTER SEWING & EMBRIODERY
I just got this sewing machine and I am trying to do the embroidery part but the display keeps showing "the carriage of the embroidery unit will move." so I push ok and it makes noise, stops and shows that message again. I can not get it to do anythig else. I have read the manuel and I put it together correctly...anyone know what I need to do...Should I take it to someone?? How much do you think it will cost??
  • 21 Answers
But is the carriage moving,? if not disconnect and try to connect again, the embroidery hoop holder usually moves to check itself, if it still does the same thing the connection that goes onto the machine is not making a proper connection, I also had this problem, with a 2100 brother , I fixed it by using a crochet hook and just tightening the connection that connects to the machine on the embroidery unit, but tread very carefully it just takes a slight move. if this fails it will have to be adjusted cost is usually $100au
Posted on Sep 21, 2008
How do you change the light bulb on the Disney 270D embroidery machinr
The Brother 270D uses an LED light. Part number XC3503021. The assembly costs about $25. I do not believe this is a user installable part.
Apr 01, 2014 | Brother SE-270D Computerized Sewing...
Hi,i have a disney sewing and embroidery amchine.It won't loop th it was threads together.Local repair man said it was o/ut of time.CAN YOU HELP/
If the timing is off is needs an authorized repairman to fix it with metric tools. Not a repair that can be done at home. Usually costs between $50-150 depending on your area.
Aug 14, 2010 | Brother SE-270D Computerized Sewing...
Its missing plastic flap in front of machine
You can order one from Ron at a1sewingmachine.com. Look in your manual to give him the correct terminology.
Dec 16, 2009 | Brother SE-270D Computerized Sewing...
I have a Disney Brother SE-27OD Embroidery Sewing Machine When I am doing the embroidery the needle comes out I put it in as tight as possible but it keeps happening from time to time.
Make sure you have the flat part of the needle to the back when putting it in and that it's (preferably) a Schmetz embroidery needle with the red band either 75 or 90 or a Schmetz universal 80. Make sure when you install it you can see the top of the needle in the needle slot and all the way up so it's hitting the post before you turn the screw tight. Check the screw each time you sew to make sure it hasn't shaken loose from embroidering.
Dec 13, 2009 | Brother SE-270D Computerized Sewing...
I need a replacement needle to embroidery. need to know the model#. I have a Brother SE-270D Easy Thread Cassette System.
The thread cassette has no bearing on what needle you use. You need a Schmetz embroidery needle with the red band size 75 for light to medium weight fabrics or a size 90 for heavier fabrics such as denim.
Dec 07, 2009 | Brother SE-270D Computerized Sewing...
Embroidery machine patterns are not consistant
I'm just beginning to work with my machine, but I have had a similar issue. Some of the possible solutions that I have found include (note: I've tried #1, I will try 2 and 3 soon)...
1. use stabilizer fabric.
2. if you're using tear-away stabilizer, and it is tearing prematurely, try a cut-away stabilizer (or maybe iron-on stabilizer?).
3. if you're embroidering on fabric like fleece, try 'hoopless embroidery' This involves using adhesive stabilizer - put the stabilizer in the hoop with no fabric, (if you don't have adhesive stabilizer, use regular stabilizer and spray it with a craft adehesive) then lay your fabric over the hoop and press the fabric onto the adhesive.
good luck.
Dec 17, 2008 | Brother SE-270D Computerized Sewing...
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
130 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
