Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi HD1080 My picture goes out. Some time it works ok for days ,at other times it goes out very often in a day
  • nestoragosto Dec 28, 2008
    The green light on my TV turns on when I turn it on then it turns back off. Is there a reset button?
Hello there, i have same problem, i removed the FC connnector, the blinking green light stop after 70 seconds, now i now the problem is on the FTM board, question is what can be bad on the FTM? 4 cap's 1000mf 16 are replaced, they are new cap's but won't solved the problem, any other tip's?
thank you very much.
Posted on Oct 29, 2008
  • 927 Answers
Good Day;
You may have a bad lamp. What lights show on front panel? Check this when no come on:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A .
Good Luck, big IRISH.
Posted on Sep 23, 2008
I have a mitsubishi medallion hd1080 60" big screen that just started flickering on and off.
Not knowing the model number I would first look for any signs inside the set of Glycol leaking.
These sets (WS or VS or WT models) have 3 tubes with a sealed area of Glycol for cooling the faces of the tubes.
Confirm actual model number and I will tell you what and where to look.
May 01, 2012 | Televison & Video
I have a Mitsubishi HD1080 TV with a fog over the picture
CRT needed coolant replacement.Try Tv repair World.com to buy coolant and a CD instructions for replacement.
Feb 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Picture on the mitsubishi HD1080 VS-50111
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Picture blinks black then back on at various times, how do i fix? mitsubishi hd1080
U could have a bad projection bulbs or a lose connections or cold soldiers joints somewhere
in the yoke connections to the main PCB or the CRT socket to the video board.
Aug 19, 2009 | Televison & Video
TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Skyassoc
Jun 19, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Red streaks across my screen of my tv
is it like a double image kind of thing?i dont know what 'red streaks' are....
Oct 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Power Problem
Most likely the power supply is failing, or some other circuit that is causing a safety shutdown.
Without doing the proper tests and diagnistics, it is impossible to accurately speculate the exact fault.
Jerry G.
Jun 01, 2008 | Mitsubishi WS-65819 TV
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi HD1080 Medallion TV
Do the self test and return with model number and I can help.
Dec 18, 2007 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
368 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
