Question about Indesit W 123 Front Load Washer
My Front Load Washer Won't Drain
I have a four month old Frigidaire Front Load Space Saver washer that won't drain. Lots of pieces of the rubber backing from a rug came off when being washed, so I'm sure that's why it isn't draining. How do clear it out?
    President:
  • 1,314 Answers
your pump is the most likely culprit if you look in side the washer you will see a seem in the tub next to that will be one of the washer tumblers take the screws out of that tumbler slide it forward there will be a hole there rotate the tub to your right and you will find the hole going down to the drain pump can check it there but i don't think you'll find any thing as that is a larger hole it think your drain pump is now if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Posted on Sep 10, 2008
Remove rubber drain from frigidaire washer
Good Afternoon Friend,
I understand you are trying to remove the rubber drain from your Frigidaire washer. Typically, this is not a do it yourself job, as well as there are no instruction manuals that give step-by-step instructions. I suggest contacting your local authorized technician for further assistance. They are trained on your particular model, and will be able to diagnose as well as determine if there are any parts that might be needed for repair. Hope this is helpful.
-Best Regards-
WP
May 24, 2014 | Frigidaire Affinity ATF7000E Front Load...
Won't drain
Check your drain hoses and drain pump. You'll also need to tilt the unit backwards and access the drain pump and clear out the coin trap.
Aug 02, 2012 | Frigidaire FTF530FS Front Load Washer
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Drain hose too short
in these cases we use a secound hand drain hose from an old washer using a rubber extender (purchase from washer repair / parts supply store) that goes over the ends of both hoses therefore extending the hose
Nov 30, 2010 | Frigidaire FTF530FS Front Load Washer
Whirlpool duet will not drain, F21 error code
YOUR "DRAIN MOTOR PUMP" is clogged with all that rubber particules, if your handy with tools , you can fix this one , open the washer , locate the MOTOR PUMP , (just follow where the drain hose is connected), remove , inspect and clean all the debris and lints and stuff collected , replaced and youre good to go , AJ
May 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
Indesit W 123 Front Load Washer Logo
81 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
