Posted on Sep 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i clear the code on the display screen?
Bubbab, many thanks for the your answer. I fixed the rollers and now how do i clear the code on the display screen?
Tim Babcock
Level 3:
  • Master 2,794 Answers
  • Posted on Sep 10, 2008
Tim Babcock
Master
Level 3:
Answers
2794
Questions
13
Helped
1128364
Points
7249
The only way to clear it is to replace the fuser rollers or the thermistor.  Clear code isn't available for override.
Error code 03130031-2F2A
All questions need FULL 'make model (what is is)' or we just guess!
Canon imagePROGRAF iPF Error Code 03130031-2F2A
ProPrinting Systems https://proprintingsystems.com > canon-imageprograf-...
Hardware error 03130031-2F2A means your imagePROGRAF cannot detect the LF home position. It also displays a message 'directing you to restart the printer.
Canon IPF 750 error code 03130031-2F2A
Copytechnet https://www.copytechnet.com > ... > Canon
Jan 31, 2018 - 2F2A is a Linefeed Error, maybe the Lubricant on the polished Metal Bar becomes sticky, causing the Carrier run too heavy. Clean thoroughly and ...
codigo en ipf 700 -710 03130031 2F2A - Copytechnet
Sep 10, 2019
Tag: 03130031-2f2a - Search Results - Copytechnet.com
Sep 8, 2019
IPF8300 error 03130031-2F25 - Copytechnet
Sep 8, 2019
Canon IPF 710 error 03130031 2F2A - Copytechnet
Apr 30, 2019
More results from www.copytechnet.com
Canon iPF5100 - Error Code: 03130031-2F2A
PrintCopy .info https://printcopy.info > code=03130031-2F2A
Code: 03130031-2F2A · Description: Feed roller home position error. · Causes: Feed roller encoder film, feed roller HP sensor, feed motor, or main controller PCB ...
Can IPF 750 Error# 03130031-2F2A. Sorry! Canon ...
JustAnswer https://www.justanswer.com > printers > avaqq-ipf-75...
Dec 13, 2017 - Unplug the power cord from the wall outlet. Press and HOLD the Power Button for 60 seconds. Plug the power cord back into the wall outlet.
1 answer · Top answer: Thanks for choosing Just Answer. I'm Kumar and I'll assist you today. Do you a
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
3answers
E000003-0000
good morning sir, my ir machine is 3300 the problem is showing to my machine is E000003-0000 please suggest me answer
Thanks
2answers
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
3helpful
I have a Ricoh Aficio 2022 which displays a service code SC545. Anyone know what this means. Do I need a tecnician to fix? Thanks Steve
This is a fuser overheating problem. I'd try to clean the thermistors and make sure they are touching the hot roller then use SP810 to reset the code. (clear modes, 1,0,7,hold down the clear stop key, enter COPIER SP mode,then go to SP810 and hit execute.
2helpful
2answers
E 003 error code on power up
The code error is:
E003: After the temperature of the upper fixing roller has reached 180C, it drops to 100C or less for 5 sec or more.
2answers
E000014-0000
yours machine problems is heater section is very hard rotate so you are clean the top roller and bottom rollers by using thinner or kerosine
12helpful
2answers
Sharp al2030 error code h4 upon power up
Here is the solution straight from the lips of tec support at sharp.
This can happen due to a power outage.
Here is how you fix it.
1. Hit clear, then auto. (clear is on the right the red C, auto is on the far left)
2. Once again Hit clear, then auto. (clear is on the right the red C, auto is on the far left)
At this point wait for the screen to go dark.
3. Type in 14 (hit the 10 once an the 1 button 4 times)
4. Hit the Green Button.
The screen will go dark and reset the copier.
28helpful
5answers
E00002-0000 error code
ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
42helpful
3answers
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
k24674
ADMIN Andrew
ADMIN Andrew
