Dishwashers Logo
Anonymous Posted on Aug 31, 2011
Mod..#17779 dishwasher problem: Lock On lite will not go off so you can start the dishwasher. I push tyhe no-heatbdry, but still won't go off.
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Aug 31, 2011
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1231984
Points
12714
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the NO HEAT DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Dishwasher won't run. Message says Control Locked.
push and hold the lock button for 3-5 secs then release
Oct 13, 2012 • Dishwashers
Dishwasher door won't latch
it is very likely the dishwasher is not levelled correctly or the springs in the door are too tight. Refer installation manual to check dishwasher levlelling and door spring is adjusted correctly. Please provide dishwasher make and model if you do not have the installation manual.
Aug 29, 2012 • Dishwashers
Lever on GE Nautilus dishwasher won't close or lock
This is not a question. Do you have a question?
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
1helpful
The Whirlpool Dishwasher GU 2400 won't staart
Sometimes I have to push the cancel button on my Kitchenaid and start over and push the selection buttons again. and then push start. Don't know if this will help.
DISHWASHER was locked now unlocked but won't run. Goes to drain/Cancel when you push the Normal Cycles
Wondering how you unlocked the dishwasher. Normally you would have pressed Heat Dry for about 4 secs.
I don't this action would have caused the problem. For dishwasher to run you need the door lock switch to operate. If door is not closed it will go to Cancel.
Check item 12 in this diagram.
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
My VZ9996U1 built-in dishwasher won't lock &
sounds like the door latch is broken, turn off power to unit and remove in side of door, about 20 screws, at th etop of th edoor you will see the latch it will have several wires going to it, you may even find broken parts (PLASTIC ) you can order parts from here http://www.appliancepartspros.com/ they have very fast shipping you just need all the info on the machine
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
