Question about Maytag Refrigerators
My Maytag refrigerator (MZD2667HES wide by side) continues to freeze fresh food. Both the damper and jaz board have been replaced. What else is left to trouble shot to determine cause?
  • 1,800 Answers
Hi.
u might need to benifit from this page
click here
best regards
wish rate this post
Posted on Sep 10, 2008
MAYTAG REFRIGERATOR MSD2756GEQ ALTHOUGH I HAVE THE TEMP SETTING FOR THE REFRIGERATOR SET AS LOW AS POSSIBLE , IT STAYS SO COLD THAT IT FREEZES MUCH OF THE FOOD .
They most likely problem is going the damper asm. that opens/closes to let air flow into the refrig.when is calls for cooling then closes when its cold enough. That damper is stuck open andletting in too much cold air. To repair that the damper assambly should be replaced ,the part # for it is 61005991 It fits in the upper left corner of the fresh food section,trying to close it some by hand now will restrict some air flow and perhaps everything wont freeze,until the damper can be replaced. It can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 21, 2011 | Maytag MSD2758G Side by Side Refrigerator
The automatic defrost cycle is not working in freezer. Can this just be low on freon and making it freeze up? I can defrost and refrigerator will work fine till it freezes up again.
Most times on your model it is the ADC or adaptive defrost control. Part number 13 in photo here=> MSD2756GEW Maytag Refrigerator Control Panel This is behind your controls inside your fresh food compartment.
61005988 Adaptive Defrost Assembly
When the fresh food compartment begins to get too cold is usually when the part #8 in that photo goes bad and that is called the auto air damper
61005971 Damper Control Assembly
More on that part next time. I believe you will be fine once the ADC is changed, Thanks, Sea Breeze
Mar 19, 2011 | Maytag MSD2756G Side by Side Refrigerator
Is there a work around for installing a new Temp Control circuit board in a GE Refrigerator Model # PSS27NGMA WW. Orig bd has 3 connectors and new bd only has 2 connectors. I am attempting to replace...
I have a feeling that the temperature control board is not the problem. The fresh food compartment has two thermistors that relay information to motherboard through your control panel. If thermistor is bad or covered by an item it will continue to cool and freeze fresh food. Your air damper between freezer and fresh food compartment may also be wide open. Click Here=> Service Manual Tech Sheet Click Here=> Tech Sheet If you need additional assistance please let me know here or HERE, Thanks, Sea Breeze
Dec 21, 2010 | Refrigerators
The fresh food compartment on my PLHS267za fridge is freezing. Have tried turning the temp all the way down and it is still freezing. What could the problem be?
damper stuck open by the fresh food thermostat. the unit doesnt know that it is cold enough so the damper stays open letting cold air from the freezer to continue to travle over.
Oct 19, 2010 | Frigidaire PLHS267ZA Side by Side...
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
MFD2561HES The fridge temperature wants to fall to from set temp 40 to 32. I set it higher and it climbs back up in time but will lower itself back down in a day or two. Why would it continue to cool...
The control board in the control panel should be regulating the air damper correctly. If the control board is responding this way the the damper is told to open too wide allowing colder temperatures into the fresh food section. The thermistor also may not be working properly or may and the board could be the total problem. This is going to be something that an Authorized Maytag Technician will need to have a look over. Switching the Control Board Part number W10207861 Temperature Control Board and 12002356 Thermistor just may solve this. Sea Breeze
Oct 23, 2009 | Maytag MFD2560HES Bottom Freezer French...
Fresh food side freezing
the air damper is stuck open or tempature control is bad. look thru the vents(use a mirror) on the left rear(top side) of the fresh food compartment (right hand door) to see if the air damper is open/closed. i am sure it will be open since your freezing food in the ref section. if it is open ,watching with your mirror turn ref (fresh food) control off. the air dmper should close, if not damper could be stuck(ice build up,piece of foam,ect) if you can determine damper door is free, then best thing to do is replace controlassy.(120.00 or so) good luck
Nov 06, 2008 | Frigidaire FRS3R5EMB Side by Side...
GLRS237ZA
sounds like the tempreture thermostat in the fresh food is not sensing the tempreture properly, or the damper assy. is not closing or stuck open. you need to replace the thermostat for the fresh food section or the damper. their is a control box kit available
by frigidaire part # 5303918283 that will solve your problem.it has the fresh food thermost,the frz thermostat the damper and the board all together it retails for 235.99 -299.99. seen it at sears for 179.99. ,price just recently went up on these kits we still have one left for 129.99 + tax. + shipping . shop around and search for the best price .you will need that part # to search for part. good luck contact us if you need to orer or have any aitional questions. thank you
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE : allbrandsappliancerepair.com
email ; customerservice@allbrandsappliancerepair.com
Jul 11, 2008 | Frigidaire GLRS237ZA Side by Side...
Refrigerator is freezing on the produce side
if you get frozen fresh food the air damper is not closing allowing too much freezer air to enter ff section, looks like an electronic controlled wide by side you have, ther should be a tch sheet with a troubleshooting guide behind the kickplate or pasted in an envelope under the front of refrig behind kickplate.
Feb 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
123 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
