Question about SanDisk 2GB microSD Memory Card
Help hi, i have a micro sd memory card & i was using it in my nokia cell phone & now i don't use that cell phone anymore & now have a motorola phone & want to use it in there but i can't seem to get it to working/open because i have a lot stored on that micro sd & i keep getting when i put it in the nokia phone it keep asking me for my passcode on that micro card i put my passcode in it & nothing.. opens it, so when i put it i the motorola it says if i use it in that phone it will erase all that i have on that micro sd card & i don't want that i want it back open to view what i have on it..
Set the password but i forget my password not open the memorycard so plz help any password remove software
Posted on Nov 25, 2011
  • 19 Answers
Insert the memory card in the nokia phone and change the settings to the memory card without password and then insert the memory card in your motorola phone.. it will fix the issue...
Otherwise, connect your nokia phone with your computer and transfer all the contents from the memory card to pc and insert it into motorolla, format the card and copy it from your pc... make sure your having pc suite for doing this...
Posted on Sep 10, 2008
How to unlock /removed password in your memory card
most of the time we are putting a password in our memory card so that the others cannot view the important and sometimes the confidential files..but unfortunately we forget it so what we are going to do if we cannot open our memory card?if we are going to a cellphone shop we are spending much money ,if we buy a new one we also spend ...
i want to share how to unlock/ removed password in your memory card micro sd...this is applicable only for the card like MINI SD(this is bigger than micro sd and used in nokia phone like n73 ,n80 ) and for MICRO SD (used in nokia E-series ,classic nokia like 3500c ,6300 ,3110c ,7210c etc and other chinaphone )...
tools you need is high end phone like nokia 5800 ,n95 ,e63 ,e71 etc...(for phone using mini sd like n73
you need an adaptor..
here is how..
1. insert your micro sd at nokia 5800 , memory card password will appear just cancel it..
2. go to menu,applications then file manager then you will see that memory card is locked.. memory card you will see memory card locked
4. press options >memory card options and format memory card will appear
5. wait until formatting is finished will now rename the memory card and the password is gone...
note: in this process all your data will be lost but but you have no choice because no other way to
removed your password than this...
i hope it will help you ,thanks for trusting fixya
on Feb 09, 2011 | Cell Phones
Unlocking micro sd memory card
please follow the instruction in this tip you can retrive the passward for your micro sd card
Jul 21, 2010 | Nokia 3110 Cellular Phone
I kept a password for my memory card, nd forgot it, please help me out with a solution, micro SD 1 GB card used in nokia mobile phone
try to reformat your memory card on other mobile that supports t-flash or micro SD except nokia..
hope it helps
Jun 08, 2010 | Nokia 5320 XpressMusic Cellular Phone
Micro sd memory card lock password forgotten
Having 2 ways: 1. Insert the Card into any Nokia s60 OS mobiles having Microsd card, Nokia n95 Like then check this to unlock
or Simply Put in Motorola Razar Mobile handset and format to have a fresh memory card
May 06, 2010 | Nokia 3110 Cellular Phone
How to remove password from micro SD card in nokia 5300
Hi there, I have a micro sd card from Nokia 5300 phone.But when i use the same card in Nokia 3120 Classic, the memory card has been locked but i did not set any password for the memory card...Can this issue be solved in nokia 3120 classic phone.Can the password be unlocked in nokia 3120 classic.........Please advise.....
Mar 10, 2010 | Nokia 5300 Grey Cellular Phone
Memory Card dnt work ? how do i fix it ?
hi..there may be a problem with your mobile phone micro-sd slot
or their might be a problem with ur micro-sd card. u can also do
one thing just take the micro-sd card and clean the pins of micro-sd
card with spirit,aftershave lotion, isopropyl or body spray. just take
the above mention chemical in a soft cotton cloth and then try to
clean the pin of sd card by rubbing the cloth on it.
try this out..
thank u..
rate me..
Apr 12, 2009 | Motorola Mobility E770 Cellular Phone
Unlock 1 GB micro sd memory card of Kingston
HI, all you need to do is to get a usb box and good flash file, insert the memory card in th usbox then flash it.
Engineer Raphael.
Sep 06, 2008 | Nokia 6300 Cellular Phone
Unlock 1 GB micro sd memory card of Kingston Made
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
Jul 19, 2008 | Nokia N95 Cellular Phone
try mo yung appliction na memorypaswordfinder
May 10, 2008 | Nokia 6300 Cellular Phone
SanDisk 2GB microSD Memory Card Logo
171 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
