Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP officejet 6110 all in one
My printer will not stop showing Error left cartridge incorrect,
I have cleaned the conections and checked the small spring and it is the right cartridge but to no avail,
please help!
  • StanFe Mar 01, 2009
    I changed my BLACK cartridge (on the right side), and now I keep getting the message "Error: Left Cartridge Incorrect". I did nothing to the left cartridge !!! Then I removed both cartridges and placed them back in several times, all to no avail.
    Said left cartridge has plenty of ink.
    Is my only choice now to get new cartridges?
    ps... this cartridge is an Office Depot brand !!! but its has been working.
I am have checked cartridges help what can I do now?
Posted on Sep 15, 2008
  • 3 Answers
Probably one of two causes:
1)Cartidge is Faulty/Out of Date/Not original.
2)Printer is Faulty.
Most HP cartridges have a specific life, no matter if you use it or not. You should check the cartridge life - its printed on the cartridge itself. If its in date and broken you can get a free replacement from HP. Try a new cartridge first.
If you are still getting an error message after changing the cartridge and your printer is no longer in warranty, its normally cheaper to throw it away than get it fixed. If its in warranty, call HP. They normally replace very quickly.
Posted on Sep 13, 2008
Error : Left cartridge incorrect
Did you just replace it? Sometimes you get a dud in a new one. Does the old one give you the error? Take it back to the store and have them test it or exchange it for a new one.
Jan 07, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Want to buy HP6110 OFFICEJET
I have a HP OfficeJet 6110 that I'm willing to sell. It is having the "Right Cartridge Incorrect" error described earlier in this this thread, and I haven't found the right fix for it yet. Worked just fine up to now.
Oct 25, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Error - right cartridge incorrect
hi
your printer can not detect right cartridge
try cleaning cartridge metal contacts with
a paper towel if keeps error
you need to replace right cartridge
If i help you pls vote me
Sep 09, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Error: right cartridge incorrect
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 05, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
a20
Dec 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
Here's the relevant link:
Cleaning the Print Cartridge
Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP officejet 6110 printer
Open the printer, pull out cartridges and put them back. If this does not work, it means the chipset inside the cartridge is faulty, you will need to replace the cartridge in this case.
Jun 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
"remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
337 people viewed this question
Seeker5211
Seeker5211
