Question about Panasonic PV-C2780 27 in. TV/VCR Combo
No Sound The sound is shorting out...if you slightley tap it, it will turn on and then any slight movement will stop the sound.
  • Onnosel Mar 18, 2008
    The speaker seems to be working. If the TV 's sound is on its loudest you can hear a humming sound, but no voises or other sounds. Can it be a setting, because of the programmer timer light that is flikkering ?
Hi i would like to as
how to get a black diagram of my t,v,,
the model is 20w10p of panasonic..... because one of the i.c is damage and i cannot figure out of the value....
pls.. help me... thanks for how the one how help me...
Posted on Jul 17, 2008
    President:
  • 3,130 Answers
Sounds like a cold solder connection on the audio output ic?? maybe even an audio plug from the deck assy.
Posted on Apr 05, 2006
SOURCE:
My behringer um300 pedal won't turn on when pressed. the sound goes through, but any slight movement makes a loud, scratchy sound.
It's probably the activate button. Maybe it is stucked, but more probably that is damaged so when you tap it with your feet, it's making these sounds...
If you don't have any or very small experience in electronics, then take it to the electronics service center for electronics engineers to look it up,
Cheers!
Sep 05, 2016 | Behringer UM300 Ultra Metal Distortion...
Why is engine is making a tapping sound?
Your valves r tapping could be low on oil. I had a slight tap in one of my cars the engine is still going strong thousands of miles later
Aug 29, 2015 | 2006 Honda Ridgeline
Brake clicking sound
I would be checking the ABS
Jan 06, 2014 | Kia Sedona Cars & Trucks
Knocking/tapping sound behind left side of engine
if the knocking is occurring while vehicle is in motion it can be a driveshaft cv joint bad..if it occurs while not moving but in gear, it could be the exhaust rattleing under the car..may also be the front end suspension bushings worn..
Feb 12, 2013 | 2001 Mazda MPV
When Im backing up and turn my wheel to the right it makes a clunking sound
You may be against the stops. this is a mechanical stop and if ANY suspension movement happens, there is a noise. Try slightly less than full turn to the right and backing up....if no noise, lube the turning stops with lubriplate (grease).
If the noise persists, investigate VC joints.
Jun 24, 2011 | 2005 Ford Freestar
My right JBL EON 15 Slight buzz and hum occasionally for months. Now very low sound I smacked it and the sound came on strong tapped again and lost sound , hit again and all is well. Checked all...
Sounds like it could be a short or loose wire going to the speakers. You can try taking the case off to look, but chances are you are going to need to take it to a professional to get it looked at.
Mar 09, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Oct 04, 2009 | KitchenAid KAWS850L Top Load Washer
Rubbing sound when turning right
Sounds like maybe just rust on outside edge of rotors is touching on spindle slightly. Try removing wheel, and check rotors for rusty outside edge. Take a hammer with safety glasses on, and tap corner of outside edges of both front & backside of rotors to remove that rusty edge. See if noise is gone after. Inspect your brakes while your at it for worn pads.
Aug 03, 2009 | 2005 Ford F-150
High pitch sound
It is the amplifier. Service will be required to repair it.
Dec 23, 2008 | JBL PSW-D110 Speaker
Audio shorting out
sounds like a bad connection on the audio output Ic or in the audieo curcuitry
Apr 05, 2006 | Panasonic PV-C2780 27 in. TV/VCR Combo
Panasonic PV-C2780 27 in. TV/VCR Combo Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
