SOURCE: hp ipaq business navigator on charge red light is
The problem is the battery, change it (buy a new one) and it will work again.
SOURCE: fail to unlock the smartphone
Unlocking your iPAQ
Follow either of these steps to unlock your HP iPAQ.
1.Tap Start > Settings > Personal > Lock .
2.Clear the Prompt if device unused for check box.
NOTE:
In case of a Strong alphanumeric password type, type your password using the on-screen keyboard.
In case of a Simple PIN password type, type your password using the on-screen numeric keypad.
Troubleshooting tip
Device fails to unlock
While using the iPAQ, if you have the following issues:
Device is locked
Password fails to unlock the device
Then, reset the device.
For information on resetting the device, check the document - HP iPAQ 600 Business Navigator Series - Resetting Your Device on www.hp.com/support .
Changing the SIM PIN
For security purposes, the SIM personal identification number (PIN) protects your iPAQ against unauthorized access. You can assign a password to protect your device and information. Your first PIN comes from your wireless service provider.
Follow these steps to change the SIM PIN:
Press the (Answer/Send) key. Tap Menu > Options .
NOTE: Alternatively, tap Start > Settings > Connections > Wireless Manager . Tap Menu > Phone Settings .
Under Phone, tap Change PIN .
Type your old PIN, and tap Enter .
Type and confirm your new PIN.
Tap ok .
To enter a PIN before you make calls, check Require PIN when phone is used check box.
NOTE: Emergency calls can be placed at any time, without entering a PIN.To remove the SIM PIN:
Type the PIN to access your device.
Press (Answer/Send) key on the keyboard.
Clear the Require PIN when phone is used check box and tap ok .
SOURCE: FAIL TO UNLOCK HP iPAQ
Hello.
From HP Support:
Unlocking your
iPAQ
iPAQ.
NOTE:
If the device fails to unlock, then,
reset the device:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01364508&prodTypeId=215348&prodSeriesId=3544355
Hope this helps.
