Pentax Optio S Digital Camera
Problem for Pentax Optio S Digital Camera
Lens cover stuck
By w4g3n3r on Apr 05, 2006
The automatic lens cover on my Optio S is stuck. The cover has a top and bottom wich snap together to cover the lens an protect it from dust. On mine, the bottom half gets stuck. Only the top half closes.
I contacted the shop where I purchased it, and they said the whole lens assembly would have to be replaced. That would cost me $300. Any other solutions?
Comments:
Nov 12, 2007
- After a couple months the debris that was preventing the cover from closing has worked itself out. The original camera in question works fine now.
Same Problem
Feb 26, 2008
-   The zoom lens stop halfway as the battery was over and inserted a new fully charged battery and doesn’t work anymore and it says “error”.
• Ricoh Caplio R7 Digital Camera
my email: attilameneses@yahoo.com-   Guest
Nov 03, 2007
-   my camera is not working when i switch on buttom kepping flsing green but nothing happen i change batrey already and still same-   lolo2
Best Solution
posted on Nov 10, 2007
Helpful)
t00nz
Rank: Guru  Cameras & Camcorders  Expert
Rating: 91%, 2000 votes
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Comments:
Nov 25, 2007
- But forgot to mention, first try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Apr 05, 2006
Helpful)
BowerR64
Rank: Wiz  Cameras & Camcorders  Expert
Rating: 80%, 976 votes
Yeah it happens on the A series canons also. They are a very thin plastick and they pivot on a plastic post they use a very low tension spring so after a while the pivot points swell up and bind. Since the covers are so thing they can sometimes waro also
Only thing you can do is try a WD40 pen, its like a marker but has the WD40 lube in it. Mark around the shutters with the wd40 mabe it will free them up. If you try and mess with it they can pop out and the parts will go flying.
Was this helpful?
Yes
No
Popular Solutions for Pentax Optio S Digital Camera
Questions and Unsolved Problems for Pentax Optio S Digital Camera
Do you recommend Pentax Optio S Digital Camera?
Answer
Answer
necesito descargar fwdc110p.bin para arreglar mi camara digital PENTAX OptioS
Answer
digital camera cd card. can i make a copy of this to another blank cd card thus have backup for cd... (More)
Answer
recently dropped the camera and the rings came off camera still works fine etc but when i plus it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pentax Optio S Digital Camera:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
